New MSPNP2 user!
I do not see a WB signal coming into the MS, the AFR shows pegged lean the entire time, are you running a wideband? If so did you wire it into the ECU?
Thats the first thing we need to figure out.
I don't have a wide and yet. I wasn't sure it would be necessary being the car is mostly stock. I have planned upgrades so this was the first step in preparation.
ok it is very necessary to make things easy on you..
i suggest the spartan2 from 14point7.com
I agree with the need of the wideband. It is quite a bit harder to tune when you do not have the ability to see what the AFR is. This will one of the main readings you will be using to dial in the tables.
