New Pictures
  • Thread starter Thread starter fatts710
  • Start date Start date Apr 12, 2009
fatts710
14
Knoxville Tn.
Apr 12, 2009
  • Apr 12, 2009
Pictures by fatts710 - PhotobucketUnder Drive Pulleys, Cold Air Intake, C&L Plenum, Accufabu 75 mm Throttle Body, Stage 2 Cams & Heads, Slp Line Lock, MGW Short Throw Shifter, Leather Shift & E-Brake Boot, Bilstein Struts & Shocks, H&R Super Sport Springs, Summit Caster & Camber plates, Steeda Ball Joints, Steeda Bump Steer Kit, 275/40/17 Tires , Aluminum Drive Shaft, Global West Full Length Sub frame Connectors, 4:10 Gears, Steeda Front & Rear Sway Bar, Welded Axel Tubes, 4- 3/4 End Links, Poly End Link & Sway Bar Bushings, J&M Rear Lower Control Arms, Rear Shock Tower Brace, HID 10000k Headlights, Satin Billet Knobs, Aluminum Rack Bushings, MM Solid Steering Shaft, 2 Chamber Flow Master Mufflers, Momo 3000 Race Steering Wheel, 17x9 Black Chrome Wheels, Stainless Steel Front & Rear Brake Lines, Front 13” Mach Rotors & Brakes, Rear Baer Plus Rotors, Mach 1 Chin Spoiler, Black Bullitt Gas Door, Honeycomb Trim Panel, Front Upper & Lower Custom Grills, tuned by Tim Barth!
eliteJAE
Stanford University
Apr 12, 2009
  • Apr 12, 2009
fail =(
flstang65
1,484
135
94
SE Georgia
Apr 12, 2009
  • Apr 12, 2009
R
Rife96GTconv
73
Sumter, SC
Apr 13, 2009
  • Apr 13, 2009
tank_567
731
26
29
Raleigh, Nc
Apr 13, 2009
  • Apr 13, 2009
here you go buddy, post your pics like this
And list of mods like this
MODS
Engine:
-Under Drive Pulleys,
-Cold Air Intake,
-C&L Plenum,
-Accufabu 75 mm Throttle Body,
-Stage 2 Cams & Heads,
-2 Chamber Flow Master Mufflers
-tuned by Tim Barth!
Driveline
-Slp Line Lock,
-MGW Short Throw Shifter,
-Aluminum Drive Shaft,
-4:10 Gears
-Welded Axel Tubes
Suspension, Handling, and Brakes
-Bilstein Struts & Shocks,
-H&R Super Sport Springs,
-Summit Caster & Camber plates,
-Steeda Ball Joints,
-Steeda Bump Steer Kit,
-Global West Full Length Sub frame Connectors,
-Steeda Front & Rear Sway Bar,
-4- 3/4 End Links,
-Poly End Link & Sway Bar Bushings,
-J&M Rear Lower Control Arms,
-Rear Shock Tower Brace,
-275/40/17 Tires ,
-MM Solid Steering Shaft
-Stainless Steel Front & Rear Brake Lines,
-Front 13” Mach Rotors & Brakes, Rear Baer Plus Rotors
Visual Mods
-HID 10000k Headlights,
-Satin Billet Knobs,
-Aluminum Rack Bushings,
-Leather Shift & E-Brake Boot,
-Momo 3000 Race Steering Wheel,
-17x9 Black Chrome Wheels,
-Mach 1 Chin Spoiler,
-Black Bullitt Gas Door,
-Honeycomb Trim Panel,
-Front Upper & Lower Custom Grills,
Nice ride, ton of stuff done to it!
genes01stang
  • Apr 13, 2009
where did you get the c-post covers and side louvers?
fatts710
14
Knoxville Tn.
Apr 13, 2009
  • Apr 13, 2009
Thanks
Thanks Tank that was real nice of you to fix my pictures. I still have trouble posting on here. I got the c-pillars off Mr. Body Kit .com & the louvers or for a 2005 Mustang. Thanks Tank God bless
scupking
1,186
Enfield, CT
Apr 13, 2009
  • Apr 13, 2009
Wow never seen c-pillars like that for are cars, I thought it was only an S197 thing. Your car looks good
flstang65
1,484
135
94
SE Georgia
Apr 13, 2009
  • Apr 13, 2009
i like the window louvres
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
