New Problems with Brake Lights
  • Thread starter Thread starter phillysooner
  • Start date Start date Feb 3, 2006
P
phillysooner
Norman, Ok
Feb 3, 2006
  • Feb 3, 2006
I have an 87 5.0 that is having some brake light problems. During the day with the lights off, if I push on the brake pedal the brake lights do not come on. I have to push really hard to get them to come on and when I do only the driver side and the third eye come on. At night with the lights on the driver side brake light is always lit (I know that it is a two tone light with it getting brighter when you step on the pedal). It is always on the bright setting. I have to push really hard for the third eye to come on as well. The passenger side never comes on. I have checked the fuses and the bulbs and all are good. I have replaced the bulb housing for the driver side one that is always in the bright position at night. What is going on? What affects the brake lights? Would the brake light switch on the brake pedal cause these problems? I really need some help.
FORCED2DV8
458
Grand Rapids MI
Feb 3, 2006
  • Feb 3, 2006
Check the switch, its up on the brake pedal, also check the grounds for the pass side brake light, should be in your trunk/hatch area, Test with a meter to see where your voltage is stopping. A manual would be able to help you locate the wires in your brake system
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Feb 3, 2006
  • Feb 3, 2006
Brake light switch or Fuse problem... I've had both. My hazard light switch causes my brake light fuse to blow... wierd. Those are the cheapest fixes and at least you'll know the brake switch is okay. It's a pain to get in though... unless you're 3 ft tall.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
A
Resolved Brake light switch
  • Alabama
  • Feb 24, 2025
4K
General karthief
Electrical Fuse 8, Light Green / Black Wire
  • bleedinggreen
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 26, 2025
bleedinggreen
