New Project, Feedback Wanted On Engine Swap
  • Thread starter Thread starter Boosted92LX
  • Start date Start date May 20, 2015
  • 3
  • 4
  • 5
  • 6
First Prev 3 of 6 Next Last
2000xp8
SN Certified Technician
Aug 8, 2003
8,061
1,646
194
NJ
May 21, 2015
#41
  • May 21, 2015
  • #41
Boosted92LX said:
Now that would be something to consider, but buying a blower for it might hurt.. my wallet.
Yep, too bad it's not just a few hour drive..
An m112 is dirt cheap, like $300
Boosted92LX
5,721
4,244
224
May 21, 2015
#42
  • May 21, 2015
  • #42
I guess I need to buy a diesel truck and a big trailer to make trips up north for hotrod parts because they are around 700 here for a clapped out one.
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
May 21, 2015
#43
  • May 21, 2015
  • #43
What about just a budget 351w? Maybe some new forged pistons on the stock rods and crank, and a basic used hci (gt40, tfs, edie, whatever you can find). the truck should already be mostly setup for it, you'd have to change the firing order in the ecu from the 302 (or im sure truck pcms can be found cheap) but should be at least around the same power as an ls with as much room to grow, without all the fab work and custom parts to make it fit.
Boosted92LX
5,721
4,244
224
May 21, 2015
#44
  • May 21, 2015
  • #44
Oh, well I forgot to mention there is something fouled in the engine management system in the truck.. most likely engine harness, but my buddy has been trying to find it for a couple years with no luck. He's changed computers, etc several time with no luck. It'll just cut out and die, won't start, then start back up and go... cuts in and out going down the highway.. I think it's a bad engine harness since that's all that hasn't been replaced, but who knows? Part of why I was going to tear it all out and start over.
Anyway, 351s are getting hard to find. I just sold one last year to @hoopty5.0 and have been looking around for another one here, a builder is around 600 bucks, and by the time you have gone through it you have several thousand bucks into it.. with a big cube engine like that (stroker) you really need larger heads than gt40 or tfs170, so you're looking at 2 grand for heads.. on top of building the shortblock.. 5k by the time it's said and done.. ugh. It can be done, but man it's a lot of work and money.. I've done it before, just looking to do something a little different this time.. does that make sense?
EDIT: sorry, I just noticed you said stock crank and rods.. I may consider it IF I can find one, but again, they are hard to find.. and expensive to fix.. and bad stock engine management..
Admin Dude
Jan 4, 1985
43,428
21,632
234
Box behind Walmart
May 21, 2015
#45
  • May 21, 2015
  • #45
LS motor ALL DAY LONG!
Oh wait... Has this been covered?
Boosted92LX
5,721
4,244
224
May 21, 2015
#46
  • May 21, 2015
  • #46
I'm amazed I haven't heard explorer motor.
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 21, 2015
#47
  • May 21, 2015
  • #47
All this LS talk and no word from @tannerc91gt... hmmm.
Why not just rebuild it with you and your boy..seems like the logical path...
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
May 21, 2015
#48
  • May 21, 2015
  • #48
hoopty5.0 said:
Oh no man. I found a GT motor/harness/ECM in Pasadena for $3k. The truck ones are even cheaper.
Im teetering on the edge of going coyote in my cobra because of this. I've got a friend that wants to buy my 5.3 pretty bad and it's wearing at me.
Prices are getting better. $ to HP is still heavily toward the LS but the cool factor is there
Reactions: hoopty5.0
tannerc91gt
2,967
234
Indiana
May 21, 2015
#49
  • May 21, 2015
  • #49
2000xp8 said:
I'm a little skeptical about that price point for a 400hp LS especially with trans.
I like gm ls2's and ls6's. One day i'll probably own a car with one, but they aren't cheap.
Cheapest one on ebay is at $3600 and it's still has 5 days to go and penty of bids. Probably goto around $5000.
I don't even think you could find the 325hp ls4 with a trans for $2500.
Even if you do actually find one at the price it's an anomaly and you still have to deal with what else it takes to make it work.
Obviously it's dependent on location but you can find nice stuff for about half or less of what's you're estimating. I've had 2 5.7s, 4 5.3s And a 6.0 to compare.
All depends what you're trying to do. eBay is a bad measuring tool, LS stuff goes for crazy prices on there.
But while the MOTOR is cheap in terms of bang for your buck don't be fooled into thinking the whole swap is cheap. Sure you can "sloppy mechanics" your way to a running car but it's thousands of dollars to do it cleanly and reliably
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 22, 2015
#50
  • May 22, 2015
  • #50
Coyote FTW
hoopty5.0
mechanicus terribilis
7,814
6,969
214
SW Houston
May 22, 2015
#51
  • May 22, 2015
  • #51
The problem with a coyote swap at your level (read: boost) is that if you really want to make a big number, the blocks start shi tting themselves around 800. A lot of the guys building big HP coyotes around me have been sleeving the blocks which is $$$$$. @Sharad does the SF have a sleeved block? I know you said it's around 700whp, what do you know about going higher?
2000xp8
Aug 8, 2003
8,061
1,646
194
NJ
May 22, 2015
#52
  • May 22, 2015
  • #52
Even ebay has them at around $300.
All they are used for is cores so someone can get it ported without pulling their car apart. Send the core to steg, pull yours off, sell it to someone at $300.
Ported rebuilt SC's sell on svt performance for about $800. I was going to go that route, just didn't feel at my power level it was worth the trouble for 25rwhp, not sure i'd notice it.
tanner, I didn't only use ebay to check for pricing, I also used the junkyard site car-parts.com then sorted by distance.
I didn't find any really cheap Ls2's, ls6's and certainly not Ls3's (they appear to be 6-10k engines). The cheapest I could find were 5.3's (and they weren't that cheap), not sure that matters though, that engine isn't worth a swap into a ford. The cheapest were the 5.7 ls6's, and that was 3 grand and up with no trans.
Even Silverado engines were $4000+
Junkyards also tend to keep the computers too, not sure about the harness'.
Not saying they are never cheap, but I don't think someone is going to wake up tomorrow, decide to do an ls swap and immediately grab one complete with trans for $2500. You probably need to find someone that doesn't know how to work the internet.
Boosted92LX
5,721
4,244
224
May 22, 2015
#53
  • May 22, 2015
  • #53
FYI: there is a lot of info out there on LS engines that will tell you to not bother with an ls1, ls3, ls6, etc.. because too many ppl want them because they don't understand the truck engines (read:lq4, lq9) make the same horsepower for half the money or less.. So many people are caught up in the hype of corvette motors, they don't take the time to read...
Boosted92LX
5,721
4,244
224
May 22, 2015
#54
  • May 22, 2015
  • #54
Also.. fwiw fellas... this truck will get mods, but not 800hp worth. It'll be a hot street truck. Keyword: truck.
edit: I'd be tickled with a coyote if I could find one... it should more than meet criteria. . I just need my buddies in NJ where they give them away to mail me one...
tannerc91gt
2,967
234
Indiana
May 22, 2015
#55
  • May 22, 2015
  • #55
Lol I tossed my ls6 for an iron 5.3 so their value in a swap is debatable I guess
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
May 22, 2015
#56
  • May 22, 2015
  • #56
At a certain hp level I believe the $$ are usually about the same.
@Boosted92LX - seems to me if you can find a LS based motor as cheaply as stated it would be a no brainer for me even if it ends up being a 4-5k swap(motor-trans-harness) I'd do it.
After all this is a "hot rod" project. Not one of our precious fox body's
Reactions: Boosted92LX
Boosted92LX
5,721
4,244
224
May 22, 2015
#57
  • May 22, 2015
  • #57
Too bad I don't have the money now..
03 - 06 chevy c3500 6.0 engine and transmition
Transmition.. lol
Admin Dude
Jan 4, 1985
43,428
21,632
234
Box behind Walmart
May 23, 2015
#58
  • May 23, 2015
  • #58
Boosted92LX said:
Transmition.. lol
Must be rare.
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
May 23, 2015
#59
  • May 23, 2015
  • #59
There's a 90 hatch around locally with the stock M50 and a DS1 that puts down right at 700 hp dyno'd, no issues, Aluminator can handle more...
Bullitt347
I have been doing it wrong this whole time
4,022
3,027
204
Middle of Maine
May 23, 2015
#60
  • May 23, 2015
  • #60
A5literMan said:
don't understand the LS hatred?! Doesn't bother me. That's what hotrodding is all about.
Maybe, just maybe it is because this is a Mustang site. If a person wants LS Loving just hop over to LS1tech.com and get all of the feel good LS warm and fuzzies you want. Just sayin................
  • 3
  • 4
  • 5
  • 6
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Need help and Advise - 89 Problem Child
  • Sheela
  • Oct 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2025
evintho
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
