New radiator questions!
WilwoodFiveO
108
VA
Hey guys i have been looking at radiators for some time now and have come to the conclusion that i wanna save up for this. do you think it would be a good buy? http://store.summitracing.com/partdetail.asp?autofilter=1&part=BCI%2D81165&N=4294908331+4294908282+4294924761+4294924500+4294839040+400001+115&autoview=sku
also would this do a really good job at cooling everything? i have heard only good stuff about Be Cool so i looked to see what they have and that seemed to hit it right on the nose. also if you think this is to much do you can you please list what you would do? thanks
thanks for all your help.
That's a little pricy. You could do the same much cheaper. Get a 31x19" all alumimum unit, and a aftermarket fan of some kind, will do the same thing but with only a fraction of the cost.
I have to agree with Jason. If you have cash and want top notch components, the all alum radiator, along with one of Baskin's fan and controller kits would be a sweet set-up (I'd use his controller no matter what fan you choose. Mark VIII and Viper fans move a ton of air, if needed).
Good luck.
ok i took your guys advice and have also read a little more into this but still have a few questions?
1.) If i get an aftermarket aluminum radiator like this http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D380451&N=400304+4294908331+4294924761+4294908282+4294840126+4294924500+4294839040+115&autoview=sku will i need a fan? will i need to order a new coolant tank and stuff like that? please help im only 16 and don't understand this stuff that much. your help is greatly appreciated.
2.) if yes to the one above should i get an electric fan or stick with stock?
3.) if i should go with electric, i need a new alternator, right? if so i am getting one anyways because im redoing my sound system? what Alternator should i get?
Thanks your help is very needed and im trying to order this by tonight too
- Cody -
I have copied this into a few other radiator threads...it should help
I went with the aluminum summit one. I would recommend the summit or griffin. I bought the summit 31" L X 19" H: part number SUM-380431. I couldn't be happier with how well it keeps temps low especially compared to the stock one. The only issue I had was the fitment, it fits in there tight (had to bend some metal lines on the passenger side but nothing serious) and because its almost 3 inches wide, the fan shroud (assuming you still have the stock one) will move closer to the fan belt. I ended up cutting the stock shroud when I had to get to the belt tensioner. So, I would recommend going one size smaller, summit makes a 27 3/8" L X 19" H part number SUM-380428. I think this may have made the install a lot easier. The other issue you will have is connecting the hoses. The inlet and outlet of the summit ones are bigger than the stock ones; I used some Vaseline to help get them on. I also cut about two inches off the bottom hose; u will notice that the hose will bend slightly due to the bottom inlet slanting up-word as well as the radiator being wider than the stock one. You will need to get a fitting to go into the radiator neck that connects to the overflow tank hose. I got this from pep boys. Also, you will have to drill holes for the shroud to hook up at the top, I used the stock shroud screws. Then drilled holes for the shroud at the bottom of the radiator; I used zip ties to hold it together at the bottom. The only other suggestion I have is to consider installing an electric fan while doing the new radiator; if you do it later, it will mean more work later on. The only thing is without the stock fan shroud, you will have to figure out a way to mount the stock over flow tank or buy an aftermarket one and mount that some how. Also, there is no drain plug on the radiator, I decided I wasnt going to spend another 100+ for a more expensive radiator with one. I don't think the griffin or jegs have them either.
Another thing to think about when deciding on the summit or griffin, is to look at the construction. The summit is fully welded while the griffin uses an epoxy seal. Most people I talked to told me to get a welded radiator. I did a little research on epoxy ones, but i'm still not too sure how they compare. During my install, I first thought I should have spent the extra money on an actual direct fit mustang radiator, but as soon as it was in I was glad I went with the summit one. Plus I was going to buy an electric fan with the money I saved but never got to it.
I know this was long, but you should have no problems with your install and it should save you some money, which is always good. Like most things, its better to do it right the first time. I learned a lot from my experience and I hope all this helps.
ok ras50gt i just realized that the one listed above is for an auto. i really need a new radiator and fan my car over heated today in litterally 15 minutes of city driving 87 degrees outside and all i have is Mac long tubes, Mac on road h-pipe, and magnaflow catback.
anybody think that this is a good one http://store.summitracing.com/partdetail.asp?autofilter=1&part=GRN%2DGMAR7993MT&N=4294908331+4294908282+4294924761+4294924500+4294839040+4294840126+115&autoview=sku its seems to be a good price and looks like a good product
i would also like to be able to use this fan http://store.summitracing.com/partdetail.asp?autofilter=1&part=PRO%2D67015&N=4294908331+4294908282+4294924761+4294924500+4294839058+115&autoview=sku
If you think that this combo would work to keep a stock 302 with full exhaust cool please tell me. also im not really sure if this fan would work with the radiator above so please tell me which one would if that one doesn't. Also i am going to be running new speakers and a new head unit ( the speakers include all new door front and back speakers and a 12" sub in the back with an amp. my igniton is going to be updated soon too. so now that question is which alternator should i get? if none listed below are good enough please link one for me thanks
** option 1 alternator http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=PA-1619M6B1%20%20%20%201&comp=LRS
** option 2 alternator
http://store.summitracing.com/partdetail.asp?autofilter=1&part=PWM%2D47759&N=4294908331+4294908282+4294924761+4294925143+4294880793+4294880691+4294908395+115&autoview=sku
** option 3 alternator
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=PA-16196B1%20%20%20%20%201&comp=LRS
well im going to be getting a 351 in july so im preparing for everything i can right now.and this is going to be cooling it in some very high temps so its not like im worried. also money isn't much of a problem me and my bro are bulding this car together and each get 900$ pay checks every other week and we like to do mostly the best we can get at the time we can.
