New ride... Hp estimate?
Slofive0
hey guys i am new to this site. I just picked up my 5.0 about a month ago and just looking to have some fun.
im just listing the mods the dude gave me when i bought the car
Mods:
289 Block Bore 40 over
ford nodular iron crank
motorsport rods
J&E nitrous pistons
1969 351 windsor 4-barrel heads, ported and polished
comp cams 1.6 roller rockers
"crower" solid lifters
comp cams solid lift flat tappit camshaft
eldebrock intake
holley 750 carb
holley vollumax fuel pump
NOS big shot 125 HO shot
billet reduction pulleys
MSD pro billet distributor with dual pickups
MSD 6AL /w soft touch rev lim.
MSD blaster coil
t5 tranny
hurst billet shifter with shifter stops
motorsport clutch and pressure plate
billet flywheel
aluminum drive shaft
lol i already blew the 7.5 rear end on it... so im in the process of putting that in
8.8 with 3.73 gears 28 spline moser axels.
what do you think my hp would be about now once i get it fixed.
The nitrous is all ran, but the arming system needs to be redone, so as of now i do not have the nitrous hooked up
really need to know more info. Are they flat top pistons, what size it the cam, how many cc's are the heads and how much there flowing? How does it run? 750 is alote of carb for that little of a motor.
1 billion H.P.
Hey whats that one thing... you know the thing you put your car in, and it does that one thing, then prints out this thing, for you thing? What's that called?
Im saying a conservative 971rwhp.
:shrug:
EDIT: I had my car put on that thing, then it did that thing and I got 1,203rwhp...but they ran out of paper to print on!
750 carb on a 289? Does it revv to 10,000rpm? ;)
"The HiPo engine was engineered to increase performance and high-RPM reliability over standard 289 fare. It had solid lifters with hotter cam timing; 10.5:1 compression; a dual point, centrifugal advance distributor; smaller combustion chamber heads with cast spring cups and screw-in studs; low restriction exhaust manifolds; and a bigger, manual choke 595 ft³/min carburetor. The water pump, fuel pump, and alternator/generator pulley were altered; fewer vanes, extra spring, and larger diameter respectively; to help handle the higher RPMs. Even the HiPo’s fan was unique. Bottom end improvements included thicker main bearing caps and balancer, larger diameter rod bolts, and a hardness tested and counterweighted crankshaft, all for high-rpm reliability. The HiPo carried SAE gross ratings of 271 hp at 6000 rpm and 312 lbf·ft at 3400 rpm."
links:
http://www.hipomustang.com/images/hipoeng/
http://www.fordmustangfaqs.com/289-windsor-engine.html
hope this helps... and welcome to stangnet.
A stock 289 hipo would be an improvement over a 5.0L... but not by much. You got to make sure it's a hipo though... Not sure about your head specs. it could be anywhere from 220 to 280hp, imo... depending on the carb and whatnot.
