New Supercharger
I have an 03 Mach 1 and i'm want to put an 03 cobra factory Eaton on it. Does anyone what the exact differences are between these cars as far as small things that will need to be added(check valves, bypass valves, etc.) I know that the internals are not forged, so i was also wondering what a safe amount of boost would be to run in it. Any info will be greatly apreciated
do you have the new setup for the additional belt?
also, try searching....this has been discussed.
8-10 psi is about max.
puttina a heaton it is a waste of money. You should look at the KB kit...you can put more boost safely and make a buttload more power...
