hello everyone! in an effort to learn hands-on repair for automobiles, i bought a 90 lx 5.0 for a steal. however, it has some problems that i'm willing to fix:
-the biggest problem is the shifting. 1st gear doesn't engage, and if i try to push it in, it just pops out. the most likely problem is that synchros and gears are beat to hell, however, i gave him the benefit of the doubt and asked him what the problem was. he said that when he installed the shifter, that he never adjusted the two bolts under the shiftboot. is this a common/possible problem?
assuming that the transmission IS shot, could someone please point me to a website that instructs on T5 rebuilding. or, would it be beneficial to just buy an aftermarket replacement?
-the car sometimes randomly stalls. one time i applied the brakes (kind of hard) and it stalled. another time when i turned the wheel really fast to dodge a pothole in my neighborhood (granted i was only going 5mph). i'm guessing this has something to do with the power brakes and power steering, somehow taking power away from the system. maybe the alternator needs replacing?
-there seems to be a "deadspot" in the steering when it's pointed straight forwards. is this common?
-if i'm not in the powerband, the car feels really boggy. in other words, it really likes gas. is this because of the cams?
since the idle is rough from the cams, i'm not sure if it's masking any other problems (maybe a piston that's not firing). i also wanted to check the compression. so, how do you check whether the pistons are firing and the compression?
the car came modded: b303 cams, headers, JE pistons, piston rings, reconditioned rods, flowmasters, 3.55 gears (i think the speedo is off, so i'll have to fix that also), aftermarket radiator, throttle body
besides that, the car runs well. i really wanted to learn how to work on domestics, and i'm told that the 5.0 is one of the easiest and cheapest cars to do so on. please bare with me. my other car is a honda accord. FWD+I4 is much different than RWD+V8. haha. thanks a lot for any help!
