hello I,m new to stangnet and have already enjoyed reading some of the posts. my son and I are working on a 94 mustang v-6 with a 5-spd trans that he got cheap because it supposedly had a dead cylinder on the drivers side rear. a good motor came with the deal. before removing the motor and installing the other motor ,I decided to checkout the dead cylinder myself and found 150lbs compression. after pulling the intake off we cranked the engine over and could see that no fuel was comeing out of the injector. the injector next to it was squirting fuel like it should so I moved the wire connector to the injector that wasn't working and now it works good , so I know the injector is not the problem. with the key on the voltage on each connector is 12v. everything seems to be ok but that connector will not make any injector work. I pulled the large square connector apart that is next to the bulkhead on the passenger side. I found the correct pins that went to that peticular injector and put 12v to those pins and got the injector to squirt fuel, so I know the connector and wires are ok. that is about as far as my knowledge will take me and I really need some help. I,m hopeing someone can help me determine why just this one injector is not getting triggerd when I know the injector is good and there is 12v to it. I,m hopeing someone out there may have had this same problem and knows the fix for it. thanks in advance. will post some pics of the car as soon as I can figure out how.
