New tubular k member
YELLOW 94
428
Rio Rancho NM
I just put the engine back in the car. I used the first slot for the motor mount, the one closest to the front of the car. Everything has plenty of clearance. I was wondering which slot you used for the motor mounts, and if you had any issues with the second slot. I tried the second slot and it pushed the engine to far back that I could only see half the bolt hole on the motor mount. I have a granatelli k member tubular a-arms and coil overs. Im installing the drive shaft and h pipe tomorrow.
Later
Orlie
I have the AJE K Member with the spring perches that allow the use of my lowers that were on the car. Mine simply bolted right up. i think the AJE is not adjustable as far as engine position.
My AJE is currently in my front room. There are two positions for the engine mount. :shrug: I too have the spring perches and will reuse the control arms until one day I decide to go to coil-overs. Right now funds are too low.
