- Aug 6, 2005
- 4
- 0
- 0
1967 Mustang Coupe, 289 was 2bbl. A new 4 bbl carb, intake manifold, cam and headers were just installed. It is running really rough, but its timing/fuel related, the engine ran fine before. I realize that I sound like an idiot here, but I do not have very much experience with tuning carburated engines. My questions are as follows. What should the timing be? Cam specs are as follows:
COMP CAMS FS 268H-10
INT EXH
ADV DUR: 268 268
DUR @ .050: 218 218
VALVE LIFT: .456 .456
LOBE SEP: 110.0
It is also running very rich. It is an Edelbrock 650 Thunder Series, 1805 Manual Choke. When you step on the gas it hesitates a great deal and sputters like crazy, when you are just party on the gas, it is okay, but as soon as you give it more it sputters and hesitates. The exhaust smells like pure gas, but we dont see any black smoke.
It would be greatly appreciated if anyone can give me some advice on this, and again sorry for the rookie question. Just trying to get an idea of what the timing should be. Thanks alot
Jay
INT EXH
ADV DUR: 268 268
DUR @ .050: 218 218
LOBE SEP: 110.0
Jay
. Not sealing right is likely. The other that could be causing it is your fuel psi. Check to make sure it isn't too high. ALSO, check down the carb when it is running to see if fuel is pouring down the motor. Sometimes new carb get packing material stuck in the needle and seat. Tap the back left and right corner of the edelbog to see if you can dislodge it.
