newbie needs help
junk89lx
dayton ohio
hello
ive got an 89 4cyl 5spd car that has an 88 5.0 auto from a t-bird.i have no computer from the bird and was wondering if an 86 gt computer will work to get me going? just trying to get it running to see what needs done next.....thanks
junk89lx said:
hello
Unless the T-bird had an HO engine, the firing order is different for the injectors. It is not a good thing to try & make it work.
To determine if it is an HO engine, remove spark plugs 1 & 3. Put your finger in #1 plug hole and crank until you see the timing marks come up & feel pressure blowing past your finger. Then put your finger in #3 plug and crank 90 degrees. If you feel pressure blowing past your finger, it is a HO engine & you can use the 86 computer.
If no pressure, it is not a HO engine and you need a different computer or a HO camshaft.
Do you already have an 86 GT computer or are you looking at buying one? Regardless if its an H.O. motor or not, you won't want to use the 86 GT computer since the 89 engine uses multiport fuel injection rather than CFI. You'll want to find a computer for an 89 or newer 5.0 with an automatic if you are going to stick with the auto and fuel injection. 89 was the first year for Mass Air Flow contolled fuel injection except for california cars.
computer is from a 5spd...guy at work was gonna let me use it....i dont think its an h.o. motor but i will check in a couple days...would like to go mass air but doing it cheap till i sell my quad......
swap
well not been on in awhile but here is what i have
89 4cyl 5spd car,88 t-bird motor(non h.o.)t-bird harness & computer
now am i gonna have to change harness for fuel pump?and headlights
and will any o2 sensors work? thnaks
