newbie needs ideas
  • Thread starter Thread starter race-a-holic
  • Start date Start date Jul 31, 2007
R
race-a-holic
  • Jul 31, 2007
Years ago I had an 85 mustang coupe.It had a older 302 with mods.It was carburerated.It run a best 1/8th mile time of an 8.19.I never sprayed that car.
I'm a drag racer at heart.
I just recently bought a 91 mustang LX coupe.It has the 5.0 with an AOD.
I will be keeping this car injected.
Only mod on it was a complete flowmaster exhaust.I bought a used alfaotto cold air kit for $20.I'm going to have to make a bracket for it.For right now,I just removed the airbox and placed on the clamp-on filter.
Things I want:
-going to pick up my draglites today
-BBK shorty headers
-3.73 gears
-subframe connectors
-driveshaft safety loop
-I bought a comp cam(similar to an E-cam).
I'll install that later on when I go into the motor.
-Is the comp.cams polymer intake worth the money?Will I need larger injectors,etc...?
I had a friend looking over the car the other day and noticed that the fan is cracked in alot of places.It concerns me that it could just come apart.
Can they really do that,and can I just replace it with a flex fan?
I've also heard that taking off the front sway bar helps when racing,but I've also heard it makes almost no difference.
I'm new to the fuel injected motors.Any suggestions,advice,or companies you really like will be greatly appreciated.
Keep in mind.This is my daily driver.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Jul 31, 2007
  • Jul 31, 2007
That's pretty quick- That's also what I'm shooting for when I do my HCI soon
-Is the comp.cams polymer intake worth the money?Will I need larger injectors,etc...? I've heard spraying it can cause it to come apart, and I've also heard that it takes away low end torque
That's what I did
20lbs and makes you car handle like ****
Hizzle
51
Fort Carson, CO
Jul 31, 2007
  • Jul 31, 2007
It depends on where you want to start and how much you want to spend. I'd go with a good fitting fenderwell cold air intake instead. I picked up an aluminum driveshaft for my '86GT for $200 and that was money very well spent. As far as your fan goes, I went electric and freed up a noticeable amount of power but at the same time I also disconnected the power steering and went manual rack, disconnected the smog and A/C, too. It's hard to say where to start, there are a lot of good little things under $300. Subframe connectors and my strut tower brace also made a huge difference, grand total there of about 300. As far as intakes go, I'm sure you will hear a ton of people here recommend you go with the Holley Systemax. Welcome back to the 'Stang game!
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Jul 31, 2007
  • Jul 31, 2007
by: strype
nope, no problem taking extreme corners here. my 86 didnt even have one when I bought it and I put one on and it didnt handle any better.
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
