Ok I know this is the most retarded question to ask and Ill probably get flamed for it but just out of curosity since I cant find any specs on it...what is the top speed for a 95 GTS? What is the 1/4 times stock? What are the ring and pinion gears for these with aode? Did all GT(s) have posi/limited slip diffs?
I like my stang a lot but it doesnt seem fast..Im assuming its a 15 second car in stock trim? I know my last car ran mid 14's and felt a lot fast(crx b16a swap) I know theres a ton of potential for the 5.0 HO which is why I got the stang and I needed a v8rwd car again
Your speedo and tach have gotta be off. I've heard of them doing 145 with a taped up front end...but realistically you will prolly see 130-140 depending on weather that day and you altitude above sea level, etc, etc. The quarter should come in the mid to low 15's somewhere and in the low 90's for trap speed. Threre are exceptions but this seems to be the norm.
