Newly Released 1994-2004 3 Bolt Alignment Camber/caster Plates.
J&M Products
Premium Sponsor
Jan 22, 2007
62
10
29
Paso Robles
1994-2004 Adjustable Camber/Caster Plates 3 Bolt
MADE IN THE USA!!!!
J&M Products has just released this super affordable alignment camber/caster plate. This plate is designed for the everyday customer who needs more adjustment than factory but doesn’t need to spend the extra money for our ultimate 4 bolt camber/caster plate. These plates allow for plenty of adjustment for those customers who need to get the Mustang back into alignment after lowering the car while allowing increased caster for better road feel, straight line stability, and better handling.
J&M 3 bolt plates are direct bolt on replacements and require no drilling for installation.
Benefits & Product Features:
  • Independant camber and caster adjustment.
  • Direct bolt-in.
  • Full range of camber for better cornering.
  • 1/4” High strength grade 50 steel. (over 30% stronger compared to regular steel plate.)
  • Allows for adjustment of caster and camber. - caster is not adjustable from the factory.
  • Perfect for street & race! (not intended for coil-over applications.)
  • Increases caster by up to 2° more positive for straighter tracking and better straight line stability.
  • Increases feel and steering response for quicker turn in.
  • Precision spherical bearing with chrome-moly alloy steel race.
  • Adjust for all driving conditions and precise alignment.
  • Lubrication free Teflon lined bearing.
  • Replaceable Bearing.
  • Variety of strut bushings allow custom adjustment of strut height.
  • You can raise the strut to increase suspension travel on lowered vehicles.
  • Allows you to lower your strut extension travel for more droop travel on drag race cars.
  • Clears all hoods and factory strut tower braces.
  • TIG welded and powdercoated for strength and long life durable finish.
  • Lifetime warranty on camber/caster plates.
  • 6 Month unlimited mile warranty on spherical bearing.
