NewTakeOff.com (NTO) - Axle Sale $100.00 Off
NewTakeOffChic
Premium Sponsor
Feb 4, 2009
48
NewTakeOff.com is offering StangNet Members $100.00 off on our Mustang Axles.
GT 8.8 Rear Axle Assembly 3.31:1Ratio w/ABS w/Trac-Loc
GT 8.8 Rear Axle Assembly 3.55:1Ratio w/ABS w/Trac-Loc Pinion Flange For Mustang GT Only
GT 8.8 Rear Axle Assembly 3.73:1 Ratio w/ABS w/Trac-Loc Pinion Flange Only Fits Mustang GT
GT 8.8 Rear Axle Assembly 4.10:1Ratio w/ABS w/Trac-Loc Pinion Flange Only Fits Mustang GT
V6 8.8" Rear Axle Assembly 3.55:1Ratio w/ABS W/Trac-LocPinion Flange For Mustang V6
V6 8.8" Rear Axle Assembly 3.73:1Ratio w/ABS w/Trac-Loc Pinion Flange For Mustang V6
V6 8.8" Rear Axle Assembly 4.10:1Ratio w/ABS w/Trac-Loc Pinion Flange For Mustang V6
Offer good thru May 15, 2010 - Use discount code 100off
Thank you StangNet Members for your business.
4.10
That is correct from Ford you can only get 3.31 and 3.55. We have a local Ford ASE mechanic install the Ford Racing 3.73 and 4.10 gears into those stock assemblies to Ford factory specs.
O.K...So these are genuine Ford Gears, as well as everything else. O.K... Do you know if these are direct fit for 2010 GT? I noticed under my car there are tags on the rear that say "NEW MODEL" I'm not sure if that means there as something different as far as the actual housing is concerned from 05-09 to 2010...
