Next Mod??
  • Thread starter Thread starter buyingstang
  • Start date Start date Aug 19, 2005
buyingstang
MD
Aug 19, 2005
  • Aug 19, 2005
My question is, on a low budget, where am I to go next for more power. I don't really want to go nitrous and college has most of my money tied up. I like the idea of supercharging but Im not too familiar with them. I'm up for suggestions and appreciate any help. Thanks.
Mods:
Jasper Performance Short Block (308ci)
AFR 165 Heads
FTI Custom Ground Cam
Comp Cams Pro Magnum 1.6 Roller Rockers
Roller Master Double Roller Timing Chain
ASP Underdrive Pulleys
Romac 50oz Race Harmonic Dampener
Air Conditioning Removed
Smog Pump / EGR Removed
SCI Custom Burnt Chip (WB tuned)
24 lb Injectors
Aeromotive Fuel Pressure Regulator
Walbro 255 lpm Fuel Pump
BBK Equal Length Shorty Headers (Ceramic Coated)
Flowmaster Delta Force Cat-Back Exhaust
Off-road H-pipe w/o cats
Ported Cobra Upper and Lower Intake Manifolds
65mm Ford Racing Throttle Body
75mm Pro-M MAF
Mac Cold Air Intake
Ford Racing King Cobra Clutch
BBK Adjustable Quadrant and Cable
Pro 5.0 Short Throw Shifter
Ford Racing 3.73 Gears
C
custom89stang
705
Seattle, WA
Aug 20, 2005
  • Aug 20, 2005
looks like u've covered it all, except for the power adders, nitrous/supercharger....you could TRY a little bigger MAF and throttle body......and try to get a few more HP out of it, but other than that man ...nm
C
custom89stang
705
Seattle, WA
Aug 20, 2005
  • Aug 20, 2005
you could switch to long tube headers....if u wanted
28
22
  • Aug 20, 2005
How abou6t doing a little suspension work to it..I know it's not a power mod,but you'll be surprised what a nice set-up will give you at the track...All the power in the world is for not unless you can put it to the ground properly...I'm assuming you alredy have subframe connectors....How about a nice set of 90/10s up front and some 50/50s in the back(shocks)...Some 4 banger springs are known to help out alot as well.I personally run 5 way adjustable Tokikos all around with FRPP Springs...They kick arse...
PS.I wouldn't go bigger on the MAF unless you went to a blower...Your MAF/TB combo looks to be right for what you have right now...Even if you got some juice.
buyingstang
MD
Aug 20, 2005
  • Aug 20, 2005
i know i could use suspension work but it looks like im gonna need to tap into the piggy bank to get some real juice
I
IntenseBlue
946
  • Aug 20, 2005
S-trim if you can go with a blower, or get a MAC 3" exhaust.
mondos90lx
243
Stoneham Massachusetts
Aug 21, 2005
  • Aug 21, 2005
do the suspension
upper and lower control arms subframes struts and shocks and that should make it feel a lot better
Daniel50
716
Discovery Bay, CA
Aug 21, 2005
  • Aug 21, 2005
another vote for s or maybe a t trim
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 21, 2005
  • Aug 21, 2005
I'm with mondo - I'd get welded-in subframes on it before I did anything else....
thumper460
3,022
Orange Park , Fl
Aug 21, 2005
#10
  • Aug 21, 2005
  • #10
Budget...?? Supercharger...?? that doesnt compute!! LOL
The cheapest way to get power for the LEAST amount of money IS N.O.S. !! Use it when you need it !! and save a LOT of money compared to what your looking into...
Just me.........................
Thumper
M
Matts89LX5.0
1,314
Long Island, NY
Aug 21, 2005
#11
  • Aug 21, 2005
  • #11
suspension...if ur looking into handling get lowering springs/ caster camber plates/ shocks and struts/ torque arm, panhard bar etc or if ur into drag racing get some drag springs with shocks/struts etc.....
but start off with some subframes and control arms
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
