next mods
FSTRDNU
76
i have a black 93 notch, with a tremec t5 trans, 65mm tb, and egr spacer, slightly ported and polished heads w/ oversized intake valves, bbk long tube headers, offraod x pipe, mac mufflers, e 303 cam, cai, b&m ripper shifter, centerforce df clutch, 373 gear, frame connectors, larger superior axels, bbk blue lowering springs, adjustable camber caster plates, adjustable shocks,
14*, and a few other little things that i probably forgot, but i just bought the car for 4500, and its nice, but not super fast.
I want to get a larger mass air for 24 lb injectors
24 lb injectors
and a trick flow track heat upper and lower intake
is that the best $1000, to spend?
if there are better options please tell me, and give me input please, thanks
I would get heads, TFS should be under 1k.
I ran high 12s with just heads, stock intake(lower port matched), 19#ers, stock MAS/TB and low 12s when I swapped to GT40 intakes still using the 19#ers, stock MAS/TB.
Wasn't mentioned above but if the stock fuel pump is still in you might want to upgrade that before injectors. I think heads wouldn't be a bad choice but you would probably add up $$$ on all the small stuff. The Edelbrock intake seems to be the better choice over the Trickflow but more $$$ as well. I have a street heat but got a great deal on it.
Some other ideas if not done yet electric fan, short throw shifter (I like my Pro 5.0), pullies (noticable pick up but can cause charging/cooling issues), upgrade ignition, dyno tune (save for last once mods are done for a bit), 75MMish mass air meter (if doing injectors), brake upgrades if still stock.
