nitour oxide and TPS wire
  • Thread starter Thread starter stevesLX
  • Start date Start date Apr 7, 2007
stevesLX
373
cincinnati
Apr 7, 2007
  • Apr 7, 2007
I have a ZEX nitrous kit here part #82015. In the diections it says that the white wire needs to be hooked up to the TPS voltage output wire. Which wire on my TPS is the voltage output wire. It also says that I need to hook one of the vacum lines to my fuel pressure regulator and the other vacum line that is supplied with the kit goes to an empty port on the manifold. I would assume that its safe to hook the other one up where the one that was going to my fuel pressure regulator was at?
SRT
29
MA
Apr 8, 2007
  • Apr 8, 2007
I dont know about the tps switch my kit doesnt use that but you are correct on the vacum line, thats how my nos kit installs as well, what jets are you using? I have mine set for 150 hp now.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Apr 8, 2007
  • Apr 8, 2007
run a search for checking TPS voltage. I tink they will confirm that the voltage out is the middle wire
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 8, 2007
  • Apr 8, 2007
TPS wire colors & functions:
Orange/white = 5 volt VREF from the computer
Dark Green/lt green = TPS output to computer
Black/white = Signal ground from computer
  • dan50
  • Jul 18, 2026
dan50
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
A
Resolved Fuel pressure high at 52 new FPR same thing
  • afjLX
  • Dec 28, 2024
  • 3 4 5
5K
Fox 5.0 Mustang Tech Jan 11, 2025
AeroCoupe
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
