Nitrous bottle mounting
  • Thread starter Thread starter 352Ford2
  • Start date Start date Jul 17, 2006
352Ford2
393
Seattle,WA
Jul 17, 2006
  • Jul 17, 2006
I have a question for guys with hatchbacks that bolted the N20 bottle brackets through the carpet and the floor. Can you still get your spare tire out, without removing your bottle brackets? Is it one of those things, if you play with it long enough you can make it work?
bubba-dough
1,044
Indiana
Jul 17, 2006
  • Jul 17, 2006
Yes. I only run the carpet and not the board/padding in the hatch area. Also mine is mounted to one side and i just slit the carpet to go around the brackets.
352Ford2
393
Seattle,WA
Jul 17, 2006
  • Jul 17, 2006
so your bottle bracket bolts do not go though the carpet, you just cut the carpet to slide around the bottle?
bubba-dough
1,044
Indiana
Jul 17, 2006
  • Jul 17, 2006
Yep.
352Ford2
393
Seattle,WA
Jul 17, 2006
  • Jul 17, 2006
thanks
anyone bolt the bracket though the carpet?
I think I am going to end up cutting the carpet though
bill302
2,131
alabama,gadsden
Jul 17, 2006
  • Jul 17, 2006
i mounted the bottle brackets and cut the carpet around brackets....on my 95 stang...if you look close to the bottom picture you can see the cuts in the carpet around the brackets....
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jul 17, 2006
  • Jul 17, 2006
mine is mounted through the carpet. i did have to remove a bunch of the padding from the underside of the carpet to make it work easier.
352Ford2
393
Seattle,WA
Jul 18, 2006
  • Jul 18, 2006
can you get your spare tire out with it bolted down?
I think I might go the cut carpet route
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
New fuel pump relay
  • Scrapla347
  • Nov 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 8, 2025
Scrapla347
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
