NITROUS INSTALL HELP NEEDED
lxwants12's
506
Im installing NX wet kit this weekend and need help with the wiring..im goin into a good saftey state of mind with it...im only spraying a max of 100 shot b/c i dont wanna risk my black..and i heard nx rates there hp at the wheels....anywayz..i got the msd retard....and rpm activated switch..the touch button one...can i set the nitrous up so that i just have a toggle inside the car and when i turn it on it only activates when the window switch rpms are in range?? or do i need a microswitch there too?? and how would i wire that?
ground of soloniods to chassis
power to rpm switch....then rpm switch to toggle..
toggle to power...
timing retard power wire spliced into nos soloniod power wire which goes to the rpm switch?
does that sound good?
Go to the MSD web site and they have good articles for how to wire up the msd activation.If I remember right the msd box will be in line of the nitrous solenoid so the msd box will only work when the toggle switch is on, and send power when you are in your rpm window. Just think of each item one at a time. Toggle switch sends power to the rpm window switch, then when you are at your desired rpm the window switch sends power to the msd box automatically retards timind and activates your solenoid for the nitrous hit. Other input from others would help. Anyways TTT for others to see.
