LS2 KLR
Mustangl3 said:So with direct port it goes through the injecters? Is a fogger kit when it is sprayed b4 the intake?
It has these cap like things that fit in the hole where the injectors go. You then push the injectors into the "caps." The kit comes with a spacer for your upper intake and fuel rails to accommodate the small rise in heigth. A fogger is a single nozzle that you tap into your intake system.
