I am wanting to put a shot of nitrous on my 74 302, will it be safe to run a 50-75 wet shot??? it has about 75k on it and I think they are cast pistons will it be okay???
as far as timing goes you are going to have to have some way to adjust it if not it will lean it self out when you hit it i mean factory setting is 10 so i would go with 8 and run it there and set it and make sure it is set at 8 before you go shotting any shot of bottle to it
I can adjust the timing but the advance is locked out so whatever i set the timing to is the total timing is what im asking. I was thiking starting around 24* - 26* with a 75 shot
