Nitrous Plugs...
zZsKyZz
503
I currently run Autolite 24's with my setup [Zex 100 dry shot]. I know I'm losing power due to running a colder plug when N/A.
Do you guys think it'd be safe to run 25's or should I stick with 24's and maybe go with the platinums or something?
It's time to change plugs anyway :-p
Platinum no good for spray either. Colder plugs wont cost you any power...how did you figure that.:shrug: The reason for different plugs is that you want to be in the optimum temp range. Too cold a plug and it will foul up...to hot a plug and you may cause pre-ignition as the tip is hot enough to ignite the mixture w/o spark or worst case melt the plug. Check your plugs (after not using the spray for a while, as nitrous has a tendency to clean things in the cylinder) and if they are fouled, your using too cold of a plug. If not then your fine. Also if the plug is too cold and you dont wanna change them...figure out how long it takes to foul them and just spray the car before that interval and they will be clean again or at least cleaner.:D
