nitrous question
  • Thread starter Thread starter fitch_fox87
  • Start date Start date Aug 30, 2005
F
fitch_fox87
Ankeny
Aug 30, 2005
  • Aug 30, 2005
Ok guys, I have a 87' GT with underdrive pullies, A/C eliminator kit, MAC cold air intake, 3.73 Gears, Trac. Lock Rebuild, Trickflow Differential Cover and Mickey Thompson 255/50/16 tires. I bought a NOS Plate Nitrous Kit adjustable from 150-300 hp and I'm wondering what your guys's inputs would be. I plan on buying a Walboro 255 pump and subframe connectors, colder spark plugs, and retard the timing along with a purge kit. I know it's speed density but can I do this without converting the mass air, and adding bigger injectors by upping the fuel pressure? Also, what kind of times would you be expecting from a car with this stuff? It's a 5 speed. I plan on doing a compression test as well.. what should I expect as a good number? My car has 90,000 miles and it doesn't burn any oil, and it seems to run strong. I'd like feedback. thanks
F
fitch_fox87
Ankeny
Aug 30, 2005
  • Aug 30, 2005
Also, I'll have it jetted for 150 horse
K
kennebell331
21
  • Aug 30, 2005
What lb. injectors ?
F
fitch_fox87
Ankeny
Aug 30, 2005
  • Aug 30, 2005
No i mean can i do this using the stock 19 pounders by upping the fuel pressure
F
fitch_fox87
Ankeny
Aug 30, 2005
  • Aug 30, 2005
also has bbk headers to off road h pipe to flowmasters with dumps
F
fitch_fox87
Ankeny
Aug 31, 2005
  • Aug 31, 2005
what do u guys think
what_stanger?
I am the mailman!!
1,697
Northern Illinois
Aug 31, 2005
  • Aug 31, 2005
i'm not really sure what difference the SD would have as opposed to the mass air, you're spraying after the meter anyway, at least i do.
i wouldn't run over 150hp, and if i were you i would start it around 75hp jets.
as far as cooler plugs & shorter gap, and retarding timing, everything should be fine.
and you could run as fast as high 11s (with good 60' times and 150shot) or as slow as 14s.
i'm guessing with a bit of practice 12s should be easy.
EDIT: is this a wet kit or dry?, sorry i've been out of the game for a bit.
F
fitch_fox87
Ankeny
Aug 31, 2005
  • Aug 31, 2005
its a wet kit that fits between the upper and lower intake has 2 fuel jets and 2 nitrous jets its just like a 1/2 inch spacer i was wondering if the 19 pounders would lean out the engine or not and i can put in bigger injectors with the speed density
K
kennebell331
21
  • Sep 1, 2005
I would highly recommend new injectors, but if your on a low budget......IF IT AINT BROKE, DONT FIX IT!
K
kennebell331
21
#10
  • Sep 1, 2005
  • #10
If you do spray your not gonna run lower than 11.9 thats for 100%. Depending on how many passes you have ran, i'd say a good runner will get 11.9 at best with what your planning to work with.
I WOULD HIGHLY RECOMMEND getting new fuel system that has patterned to aim straight for the intake valve, thus creating no nitrous rebound into intake plenum which can cause cylinder damage and your engine will live happily ever after.
And dont take my word for 11.9, i could be off.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Sep 1, 2005
#11
  • Sep 1, 2005
  • #11
Do exaclty what you were palnning on doing.Install the kit,as per instrucktions,get the bigger pump.You dont need larger injectors because its a wet kit and will inject its own fuel via a solinoid.I would get the Autolite racing plugs in 1 or 2 step colder and retard the timing to 8* int.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Sep 1, 2005
#12
  • Sep 1, 2005
  • #12
Oh,if the 150 shot is as low as it goes,use that.
If everything is set-up right it will be just fine.
Have fun once you get it working.
F
fitch_fox87
Ankeny
Sep 1, 2005
#13
  • Sep 1, 2005
  • #13
Would an MSD ignition box really help me that much. Would anyone reccommend using one.
SQUEEZE&STROKE
SOUTHERN CA
Sep 1, 2005
#14
  • Sep 1, 2005
  • #14
Depending on the plug gap the stock ignition spark might blow out...thats where the MSD is supposedly supposed to help.
K
kennebell331
21
#15
  • Sep 1, 2005
  • #15
Nitrous is a oxidizer, which carries more oxygen to the engine, which allows FASTER burning of the fuel.
To lean of a mixture can cause detonation and New Orleans style disaster.
Like venom said, if everything is setup right youll be fine, and with stock injectors w/ 90,000 miles, 150shot is asking a little too much.
I would highly recommend a fuel pressure safety switch, even if you do decide to change your fuel lines.
And of course, don't ever use less than premium pump fuel.
HAVE FUN!!!!!
Swarzkopf
973
Pittsburgh
Sep 1, 2005
#16
  • Sep 1, 2005
  • #16
I wouldn't spray a 150 shot on a stock 5.0 with a stock fuel system. 125 is considered the safe limit.
The injectors don't matter as much here, as you are dealing with a wet kit. You will absolutely NEED a 190lph or bigger fuel pump and an adjustable, aftermarket regulator would be beneficial as well.
R
rustydailey
#17
  • Sep 12, 2005
  • #17
I spray a 150 on my stock fuel system with no problems. Ran 11.9 with it, although I am using 24# injectors.
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
T
2004 SN95 W/ 3.9L Swap or turbo question
  • ThePIFFProject
  • Jun 11, 2022
1996 - 2004 SN95 Mustang -General/Talk- Jun 14, 2022
ThePIFFProject
T
Forced Induction Couple of questions for foxbody on3 turbo guys
  • Mstng93SSP
  • Apr 7, 2021
4K
Fox 5.0 Mustang Tech Apr 21, 2021
Mstng93SSP
