Nitrous setup suggestions
  • Thread starter Thread starter Igofaster13
  • Start date Start date Feb 25, 2012
Igofaster13
170
San Diego
Feb 25, 2012
  • Feb 25, 2012
Input on a crude setup for a 125 wet shot on a 88 sd car? I know to lower the timing down but what to? Running 14 degrees timing na, 190 fuel pump, motocraft sp's. Just bought the Nitrous Express (NX) 20421-10 wet kit.
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Feb 25, 2012
  • Feb 25, 2012
I backed mine down to 10* when I ran a 125. Never had an issue but every cars a little different
Jason 302
685
71
68
Newark, Ohio
Feb 26, 2012
  • Feb 26, 2012
Go about 2 heat ranges colder on the spark plugs as well. Be careful running a wet shot through the upper intake, I've seen them puddle fuel in there which makes for a pretty good show
Igofaster13
170
San Diego
Feb 26, 2012
  • Feb 26, 2012
Cool, will look into plugs.. Yea was thinking 10-12 on the timing side of things... Heard about the puddling/wet nitrous thing, but also heard that was a myth to some degree... never seen it happen on all the wet 125 shot cars in the past...
Jason 302
685
71
68
Newark, Ohio
Feb 26, 2012
  • Feb 26, 2012
Basically fuel can/will puddle in the upper intake, but it shouldn't ignite because the intake itself shouldn't be hot enough. But if something hiccups, backfires, or goes wrong....it goes wrong badly lol. I've debated running a dry shot, but now with my 4.10 gears I'd be out of revs in 4th.
9sec93lx
12
Florida
Feb 27, 2012
  • Feb 27, 2012
Rule of thumb for timing retard is 2 degree per 50 HP, so that would mean a 5 deg. retard for your car to start with. Better safe than sorry I always say. You can always bump it up (slowly) later, 1 degree at a time. Keep a close eye on your spark plugs. If the electrodes start turning blue you're riding on thin ice. Once again starting 2 ranges colder won't hurt you, better too cold than too hot. With the electronic ignition on the Stang they probably won't foul out on you.
http://www.bestracingtips.com/power-building/how-to-build-a-650hp-na-ford-5-0-mustang-racing-engine/
  • dan50
  • Jul 18, 2026
dan50
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
L
90 Fox-Megasquirt Difficult start (stock engine)
  • LX2C
  • Aug 3, 2024
  • Digital Self-tuning Forum
Digital Self-tuning Forum Feb 25, 2025
LX2C
L
