Nitrous Window switch users... need opinion
Road_Runna
Dec 23, 2002
594
Ogden, UT
http://cgi.ebay.com/ebaymotors/MSD-window-switch-P-N-8956-V6-Mustang-nitrous_W0QQcmdZViewItemQQcategoryZ107062QQihZ016QQitemZ260131238974QQrdZ1QQsspagenameZWDVW
Is this a good RPM window switch, or are the digital window switches alot better? mind you, my car has a 302 and not a 6 cyl engine, that rpm window switch was programed for a 6 cyl engine.
Also, Nitrous users what RPM do you guys hit the nitrous at?
I bought my kit from ebay, and came with no instructions. it's a zex dry kit. Can anyone email me the instalation instructions?
i use that same window switch and it works great i recommend it and to convert it back to work with a v8 engine you would just connect the blue wire that was cut to be enable it to be used with a v6. it has the correct pills too i activate with the 3000 rpm pill and deactivate with the 5600 rpm pill i paid prolly about $80 for my setup this may be a steal if bid remains low...and msd has a site for install instructions click on link....what kinda nitrous system are you using?
http://www.msdignition.com/pdf/8956_frm24819.pdf
I prefere the digital ones as you dont have to worry about pills and can change your settings at click of a buttom. You can start spraying after 3k rpms
