  • SN95 4.6L Mustang Tech
Nitrous with Longtubes... Can you do it?
  • Thread starter Thread starter TweekedGT
  • Start date Start date Dec 31, 2004
TweekedGT
1,274
Alberta
Dec 31, 2004
  • Dec 31, 2004
I have heard that you cannot run nitrous on a car with longtube headers and a being catless because the nitrous setup needs the rich/lean input from the O2 sensors. Is this truth or fiction? I want to get nitrous on my car but I'm not sure now because of my longtubes. I think I saw the whole no nitrous with longtubes posted from someone here. Just want to make sure I'm gettting the right info. Thanks.
Z
zcs626
260
dallas
Dec 31, 2004
  • Dec 31, 2004
get a tune? im not sure
J
just some guy
723
FL
Dec 31, 2004
  • Dec 31, 2004
uh, you still have 02 sensors if you have lts.
theguyfromfaust
83
Grande Prairie, Alberta, Canada
Dec 31, 2004
  • Dec 31, 2004
I have never heard of anything like that before. There's tons of people on here with LT's and Nitrous. I don't think it's an issue at all. Just make sure you get it tuned. Where in Alberta are you, just out of curiosity?
Red35th
609
Houston, TX
Dec 31, 2004
  • Dec 31, 2004
That is NOT true at all.
Only 2 kits out there even use the 02s at all (Venom for one). Every other kit (NX, NOS) doesn't rely on the 02 sensors in the least. Wet and dry kits add fuel independent of the 02 sensor readings. Also, since the front 02s are narrowbands they only read above or below 14.7. If the a/f on your nitrous car gets even close to that you will quickly lose and engine.
Also, adding longtubes will not affect the reading of the front 02s, not sure who spouted that info.
Get nitrous, more specifically get an NX wet kit and be done with it.
Edit: If you are refering to many people ditching the rear 02s with longtubes then it has no bearing what so ever on your car other than for emissions. Front O2s read above/below 14.7 and aren't replaced with longtubes. The rears are usually ditched as their only purpose is for emissions.
TweekedGT
1,274
Alberta
Dec 31, 2004
  • Dec 31, 2004
Sorry, I proably didn't make myself too clear on this one. I think the issue was more having no catalytic converters than it was the longtubes. Anyways it sounds like it shouldn't be a problem. I'm from Medicine Hat in Southern Alberta. Not a lot of tune shops around. For quality tunes I'll have to go to Calgary in the Spring. There is a guy that is about 45 minutes away near Brooks but he is always way too busy and I don't think he has a lot of experience with our 4.6's. Thanks for the info guys. I guess I can get my nitrous after all. I just wanted to make sure so I didn't go buy a kit an then have to change my exhaust set up.
Ryan02Stang
1,181
Arlington Heights, Illinois
Dec 31, 2004
  • Dec 31, 2004
Longtubes and catalytic converters will not affect nitrous at all.
white99gt
4,649
stockbridge,Ga(near atlanta)
Jan 1, 2005
  • Jan 1, 2005
REally?
Longtubes DO effect your front O2 sensors.WIth longtubes it takes them longer to warm up and they are slower to respond until they are warmed up..
As far as effecting the car with NOS ,it has nothing to do with it..
Best bet is to get a tune for the kit you use..
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
  • Gulftown980x
  • Jul 29, 2026
squeak93
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
H
SOLD Mac offroad Hpipe for longtubes. New unistalled fits 5.0 foxbody/sn95 5.0 $300
  • Hizdudeness
  • Feb 5, 2025
  • Other Classifieds
Other Classifieds Feb 8, 2025
Hizdudeness
H
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
