nitrous?
  • Thread starter Thread starter KBExperience
  • Start date Start date Aug 17, 2009
KBExperience
466
Houston
Aug 17, 2009
  • Aug 17, 2009
so i bought my car a few months ago, and i think someone used nitrous on it.. there's a hole next to the cig lighter, where it looks like a switch used to be.. and today i checked, there's a hole in my intake a few inches from the throttle body.. so im guessing someone used nitrous on it? and also, isn't that hole in my intake a bad thing? should i plug it up?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 17, 2009
  • Aug 17, 2009
If air is getting into the intake after the MAF then you need to plug it immediately yes.
You also need to verify what kind of tune the car has.
Also, I would suggest tracking down the seller and beating him about the head and shoulder area for a significant period of time.
KBExperience
466
Houston
Aug 17, 2009
  • Aug 17, 2009
well, i bought it from a dealer..
what should i use to plug the hole?
kuwait
194
Aug 17, 2009
  • Aug 17, 2009
if you had a hole in your intake your car wouldn't idle correctly , post a picture of the said hole.
KBExperience
466
Houston
Aug 17, 2009
  • Aug 17, 2009
there's definitely a hole there, yet the car idles perfect
joshjwc9
1,095
17
39
Palm Harbor, FL
Aug 17, 2009
  • Aug 17, 2009
That is nothing, but I would get a longer piece of hose to cover the hole, because your car still is running lean more likely than not at WOT. The Steeda piping I have didn't have one extra hole but two (one was for nitrous and the other was for the IAT sensor, but my kit didnt have the grommet, so I covered it with a longer piece of silicone hose for both holes).
And I would think that yes, your car or at least the intake on it was plumbed for nitrous at some point..
KBExperience
466
Houston
Aug 17, 2009
  • Aug 17, 2009
yeah.. its got holes in the trunk where the bottle was.. and theres a hole in the dash and intake and somebody tapped the tps wire.. so yeah..
should i be worried about my engine?
joshjwc9
1,095
17
39
Palm Harbor, FL
Aug 17, 2009
  • Aug 17, 2009
If it runs fine, idles fine and has good oil when you change it, it should be just fine, but I would cover up the hole with a longer silicone hose to cover that up. Also, I would check the plugs to see if they changed them to a heat range colder and didn't change them after..
kuwait
194
Aug 17, 2009
  • Aug 17, 2009
you should be fine as josh said , if your car was damaged due to the nitrous it would have been obvious , nitrous itself isn't that harmful , its people misusing it , and that hole does look like it was used for nitrous , i would repeat what other people said , check what heat range your plugs are if you haven't changed your plugs before , but first things first , plug that hole!
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
A
79 mustang pace car spoiler.
  • Anglosaxon83
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2026
Anglosaxon83
A
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
