Nittos on 18" bullits?
Remind me...I searched but surprisingly did not find any threads, although I'm sure I've seen at least one. Is there a 555R that will fit on the 18" Bullit wheels? You know, the ones they have at MustangTuning.com and elsewhere, very common. The wheels are 9" wide, and Nitto's chart states the 305/45 as fitting a 9.5-(10.0)-11.5 and the 305/35 as fitting 10.0-(11.0)-12.0. I've heard the Nitto's run narrow, so would one of these be ok for the 9" wide Bullits?
I8URVTEC said:
Wondering the same thing myself. I am going to be getting the same wheels. You are going withe deep dish bullits right? If so post some pics when they are on.
The set I was looking at (past tense) were the non-deepdish, which are 9" on all four corners. The Deepdish are 9" fronts and 10" rears, so you have nothing to worry about. You can fit 305's on those rears no problem.
But I think I am going to hold out for the deepdish also, I just want the retooled ones that don't require the spacer on the fronts. IF they ever actually retool, that is.
