no bypass valve??
  • Thread starter Thread starter 88mustng
  • Start date Start date May 11, 2004
88mustng
76
NJ
May 11, 2004
  • May 11, 2004
got my s-trim today and realized theres no bypass valve on it, is this cool?? isnt that bad for it??
will it be cool to put on with a bypass valve???
thanks,
steve
BlackFox5.0
3,514
Massachusetts
May 11, 2004
  • May 11, 2004
On an s-trim, I wouldn't like that. it's recomended that 8psi and above should use a bypass, plus it's open at idle so the air is not forced into the TB cause the blower still blows a lot of air at idle...
88mustng
76
NJ
May 11, 2004
  • May 11, 2004
im only gonna have 5-6 lbs of boost
is it still needed?
BlackFox5.0
3,514
Massachusetts
May 11, 2004
  • May 11, 2004
I'm running 6psi on an A-trim, and I think it's causing some drivability problems, like surging idle, etc....I don't have the bypass on mine because i don't have a vortech discharge but am supposed to get one from someone I know soon....i have a upgraded bosch bypass...but like i said it's not in, but I wish it was!
RydeOn
Licensed to Chill
6,273
orange county, CA
May 12, 2004
  • May 12, 2004
is it still needed?
Yes. Put it on or the car will drive like crap.
T
TheUser
1,859
Springfield, MO
May 12, 2004
  • May 12, 2004
I was pushing 9-11 lbs and my car wouldn't idle for crap...it would actually die when stopped if I didn't hold the gas. I guess it COULD have been other things, but I think others have had the same type of thing w/o a bypass. I'd just put one on so you're safe, however I also have read that w/ 6 lbs or under, a bypass isn't needed, so...I guess this post really didn't help much huh?
ss93cobra
1,422
Wilmington NC
May 12, 2004
  • May 12, 2004
A bypass valve will stop it from popping through the exhaust coming down from a high rev too. (did on mine anyway) I running one with only 6lbs
Forced Induction Bypass valve reference
  • JD1964
  • Jun 1, 2025
Fox 5.0 Mustang Tech Jun 1, 2025
JD1964
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
