No clue how fast I'm going....
BAD67FUN
589
Wisconsin
Okay.. .somebody can figure this out hopefully.
I have a 67 that has original C4 and came with 2.79 gears.
No clue on the factory tire size.
I now run 275-40's (17's if you have to know) and 3.80 gears.
I'd like to know how fast I'm going at different RPM's. Or at least a ballpark guess. 30mph, 40mph, and 50mph would be good to know. Since I'll be driving it now like a stock car on pit road (no speedo's... just tach's).
Thanks.
I have this problem too. When im doing about 55mph, the speedo says 80. How do I fix this, i know its a gear in the tranny for the speedo thing, but what should I change it to??
67 Coupe
Factory C4
2.83 rear gears
245/60R14 rear tires
Thanks
OK, first you need your tire diameter in inches
Tire Dia. in Inches = [2 x (section width / 25.4) x (aspect ratio / 100)] + rim dia
*Gear Ratio = Transmission Gear Ratio * Rear Gear Ratio
Then you can use
MPH = ( RPM x Tire Dia) / (Gear Ratio x 336)
-OR-
RPM = (MPH x Gear Ratio x 336) / Tire Dia
Ex. 50 mph, with a C4 in 3rd gear, 2.79 rear gear, and 275/40-17 tires
TD = [2 x (275/25.4) x (40/100)] +17 = 25.66 = 26
RPM = [50 x (1 * 2.79) x 336) / 26 = 1803
Forgot to add, Print yourself out a little piece of paper with the common speed limits on them and the corresponding RPM so you can make sure you're at the right speed if you are being "monitored"
Hope it helps guys
Here is your chart based on 275x40x17, 1:1 (3rd gear c4) and 3.80 rear.
