No egr do i need vac lines
5.0H.O
25
b'ham, AL
Okay i have deleted the egr since ive started my rebuild do i need the old vac lines that go to it and if not what do i do with them and could somebody please tell me which colored lines i dont need
If you removed the smog just plug that rubber tri plug good, and stuff it into the fender...they feed to solenoids up there. The pink and white feed the diverter valves you removed...
this is what you removed...red. green, white. the white goes to one of the diverters, the pink must of connected to another...
What did you guys do when the CE light came on? I have a fox body egr valve that is "hooked" up but not installed to prevent it from flashing the code:shrug: I have the valve bolted to the firewall:rlaugh: It looks so out of place, peeps do a double take when they see it.
Where's your stock EGR?? All you need do is unbolt the plug portion and secure the plunger 1/2 way, leave it plugged in an you'll never get the CE light..
Not sure if the Fox EGR is different and the ECC see's that??
I homied mine with wirenut inside this section of line...it secures the plunger 1/2way just fine....Tuck it away outta sight..
Stock egr diaphram ripped so I grabbed one off a fox at the junk yard. I need to do as you did and keep the plunger pushed in just been lazy about it.
