No headlights
  • Thread starter Thread starter 10secgoal
  • Start date Start date Dec 14, 2004
10secgoal
2,801
San Diego
Dec 14, 2004
  • Dec 14, 2004
It has been a while since they worked. I figured after sitting in the weather for a year it was just the bulbs themselves. I replace one and still nothing. Test the circuit, no power. "OK" I think to myself. I have power out of the switch and into the dimmer switch, but no power was coming out.So I buy a new switch and still nothing. So I try to jump it with a paper clip, but still nothing. The paper clip tested hot. WTF ?! Wiring diagram shows power into center wire of dimmer switch and out to headlights. Hence the paper clip. Two bad pieces ? Would think it's unlikely.
65stanger
big blue fuzzy closet monster
3,885
In the Deepest, Darkest, corner of THE CLOSET, whe
Dec 14, 2004
  • Dec 14, 2004
Don't assume that just because there is power to the dimmer that the light switch is good. There is a built in circuit breaker in these switches that can and will go bad preventing your headlights from coming on at all.
krash kendall
1,258
Aldergrove, B.C. Canada
Dec 14, 2004
  • Dec 14, 2004
Check your firewall connectors and grounds.
Use a test light (not paper clip) to see if you have power at the headlight plugs. Ground the test light to the negative side of the battery. If you have power there, then the ground from the plug to the body is bad. If no power then go back to the firewall connectors. The bullets in them work their way out over time.
I don't no what year your car is, but here are some schematics and pictorals that will help you.
Schematics 64 1/2 to 67
10secgoal
2,801
San Diego
Dec 14, 2004
  • Dec 14, 2004
Right, right.It didn't have power at the plug into the headlight itself. The paper clip I used to try and jump the plug wires like the dimmer switch was working. Does that make sense ? Thanks for the shcematic. That was the one I used. It is #15 that is hot. But from there it goes to the head lights. But I think the bullet plugs sounds about right.But why wasn't the dimmer switch transfering the power ? I checked right at the plug connection. (Either of them. I bought another one?) ????
10secgoal
2,801
San Diego
Dec 14, 2004
  • Dec 14, 2004
Damn it was the ground. I guess after I found a good ground for the test light I moved it or something. The headlight tested negative the first time. So where does this things ground run to ? I don't want to cut it and reground, but I will rather than tearing apart all the wiring to find it. It's a 67 by the way.
krash kendall
1,258
Dec 15, 2004
  • Dec 15, 2004
They usually screw to the rad support with an eye splice. you may have to take off your headlight door to trace it.
10secgoal
2,801
San Diego
Dec 15, 2004
  • Dec 15, 2004
Thanx, that will help alot !
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
G
1995 Mustang GT- No PCM Communication, Runs Rich, Lacks power
  • gtrob
  • Aug 30, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Aug 31, 2025
