No injector pulse. Complex wiring issue. Help!
Brn N Rubr
Moore, OK
I was referred here by a gentlemen on TurboMustangs.com (a place I visit on a regular basis). I am in desparate need of help. I can't get my car running after days of trying. I think I have included all the pertinent information in the following paragraph (copied from my original post on tm.com). If you have any more questions, don't hesitate to ask. I want this thing running! Thanks in advance for any info you might be able to give me.
Ok, my car has been ready to start for a week and a half now. I still don't have an injector pulse. I have a '67 Mustang with an EFI 5.0L with a single MP T70. I am using a '88-'89 California (MAF) 5.0L harness. I have spent a few hours, in multiple sessions, on the phone with a gentlemen named Jeff at Ford Racing's Tech Line. He is extremely knowlegable about the EFI harnesses and complex wiring issues. Here is what I have learned from him. The TFI module sends a signal simultaneously to two places. One to the coil to let it know when to fire, and two, to the computer to tell the computer to switch the ground on to pulse the injector. Now, in wiring the harness, there are two wires (near the EEC connector) that must be spliced into to power up the harness. A red/blue wire and red/green wire. The red/blue wire gets a 12V run only source. The red/green wire gets power in both the crank and run situations. We have confirmed the proper operation of this by probing the 12V lead on the injector plug with a DVOM and seeing that in fact it does have 12V during crank and run key positions. Next, we tested the wires between the TFI module and the actual computer connector. I probed pin 16, 36, and 56 in the computer and verified continuity with the proper wire at the TFI module. All three had continuity. Next, we made sure the computer had the proper power and ground circuits for itself. Probing pin 40, 60, 37, 57 (maybe one other - have it written down at the shop) revealed that all circuits were intact and had power and ground at the appropritate places. We thought the computer itself might be bad. I installed my computer into a known running vehicle and it ran with no problems at all. I did the same thing with the TFI module. I also checked for any expanded pins at the computer connector. One seemed slightly large but did not change anything when squeezed back together. Our next idea is something is bad in the harness. My car has not been running for approximately six months. During this time, the computer was never disconnected. The engine has been out of the car and the wiring harness has been zip tied to the fire wall. Previous to this, the car was running just fine. I also tried cranking the engine over while I wiggled the wires on the firewall to possibly discover a short/broken circuit. This was to no avail either. I don't know what to do. For some reason the computer isn't receiving the signal from the TFI module so it can pulse the injectors. This is even though the wires between the TFI module and computer are good and have continuity. I am in the process of looking for a new harness to try (hard to come by). Does anyone have any ideas to help me get this thing going? It's killing me. Thanks.
Bryan
im sure you have a wiring diagram but here is another one that has helped me out a few times
it seems like you have covered all the bases. let me look at the diagram and see if i can come up with anything that you havent tried yet.
could the pip module in the distributor be bad? thats really the only thing left you havent tested. or you didnt say you tested it.
courtesy of Jrichker (since he hasnt posted it yet):
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 31-Dec-2006 to include Noid light placement
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
J.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiBr...3d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/g...3d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/g...3d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/g...3d80167162.gif
http://www.autozone.com/servlet/UiBr...3d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/g...3d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/g...3d80195960.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) 86-93 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running. If fuel is coming out the vacuum port, the regulator has failed.
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
6.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
__________________
The PIP signal is generated by the TFI module. I had the module tested at Autozone and it was good. I also installed my TFI module on a known running vehicle and it started with no problems. Thanks for posting that checklist. Very helpful. Unfortunately, I don't think my problem was covered in there as all those things have been checked.
The PIP signal isn't generated by the TFI AFAIU. The PIP is where the base timing signal (for injector and spark) originates.
If you have no spark and no injector pulsing (more specifically, no ground pulse from the injector drivers), ECU's thought about the PIP is a very wise one. If you do have spark, you can assume the PIP is functional and move onwards in the ignition testing.
Good luck and welcome to the boards!
hmm...well you have spark and no fuel. have you tested the injector control wires for continuity to the computer? pins 13,12, 58, 59, 14, 15, 42, 52?
also, there is a ground for the injector harness that is bolted to the back of the lower intake. make sure that is actually attached and that it has a good connection.
Yep. At the time I had the noid light on injector #4. With the computer disconnected and the key ON, you can ground out pin 13 at the computer connector and the light will come on. I did not do it injector by injector, but I feel that test was sufficient. And the ground (orange wire) is hooked up to the LH rear intake manifold stud.
It was mentioned on another forum that I should also check my TPS. I was told that if the computer sees more than 4V during a cold start that it will go into "clear flood" mode and turn the injectors off. That's item #1 for today. After that, I am going to remove the PIP wire from the harness and check it for short circuits.
That is correct about the TPS cutting cranking fuel at WOT. It's actually more like anything over 3.71 TPS volts killing the injectors (2.71 volts over baseline is what the computer sees as the WOT threshold).
Good luck.
Problem: you have spark but no injector pulses. There are no stored codes that indicate a fault condition.
To create the injector pulses you need 5 things:
1.) Trigger pulse from the pip
2.) Ground for the computer
3.) Good power to the injectors
4.) A working computer
5.) Good power to the computer
Let's start with the easy stuff first:
A.) The computer works OK in another car. That eliminates the computer.
B.) You have a trigger pulse from the pip because you have spark. That eliminates the pip itself as being the problem.
The pip signal will cause the coil to fire even if the computer does not see it.
This an electrical problem, so we are going to need some electrical tools:
DVM
Jumper leads with alligator clips on them, 6’ long 18 gauge wire.
Jumper leads with alligator clips on them, 2’ long 18 gauge wire.
3 or 4 ohm 50 watt resistor with jumper leads and alligator clips. Solder the 18 gauge jumper wires to the
resistor leads and cover the solder connections with heat shrink tubing. This resistor will be used to provide
a current load when testing the wiring for its actual operating resistance. An ohmmeter does not provide
sufficient current draw to stress poor connections. The 50 watt resistor will draw 3-4 amps, and is well within
the current carrying capabilities of the wiring and circuits being tested.
Some reasonable way to detect pulses. This is a tough one, because the traditional way to see pulses is
through the use of an oscilloscope or graphing DVM. Neither one is cheap, although add in USB oscilloscope
adapters for computers are now available for less than $120. A digital logic probe would also work, and they are
small and less expensive (>$30) than oscilloscope or graphing DVM.
Now that we have the tools lined up, let’s get started.
That leaves you with 5 questions:
1.) Does the computer have sufficient ground to fire the injectors? Pins 40 & 60 connect to a pair of 14
gauge black/green wires that form up to a single wire that connects to a dedicated power ground that
comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become
corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt
green wire. You'll find it up next to the starter solenoid where the wire goes into the wiring harness. Make sure
that ground is intact. Don’t just ohm it out, physically trace the connection. The computer case ground (pin 20)
will provide a ground path, but it isn’t good enough to do everything. Disconnect the computer connector by
loosening the 10 MM bolt that secures it in place. Connect the 50 watt resistor jumper to 12 volts and to pins
40 and 60. Measure the voltage drop between pins ground and pins 40 and 60: it should be less than .5 volt.
More than that means a high resistance connection somewhere.
2.) Do you have enough power to run the computer? Connect the 50 watt resistor to ground and to pins
37 and 57 and turn the ignition switch to the run position. Measure the voltage drop across the resistor: it should
be battery voltage +/- .5 volt. Less than that means a high resistance connection somewhere.
3.) Is there enough power at the injector leads to operate the injectors? Connect the 50 watt resistor
to the red wire on an injector connector and then to ground. Connect the meter up to the red injector wire
and ground. Turn the key to the run position and check the meter reading. It should be 12 volts or battery
voltage +/- .5 volt. Less than that is a high resistance connection in the circuit.
4.) Is the pip pulse present at the computer? Let’s try a simple approach of checking the wiring quality.
Remove the TFI connector and connect one end of the 50 watt resistor to the blue wire. Connect the other lead
of the 50 watt resistor to 12 volts or the battery. Inside the car, connect pin 56 on the computer connector to ground.
Measure the voltage drop across the resistor: it should be battery voltage +/- .5 volt. Less than that means a
high resistance connection somewhere. Disconnect the jumper between ground and pin 56 on the computer connector.
The voltage reading should drop to zero or close to it. If it stays high, there is a short to ground between
the pip lead and the chassis.
5.) If we have gotten this far, we need a means to measure and view pulses. Reconnect the computer
connector inside the car. Probe the dark blue wire on pin 56 from the rear of the connector. Use your pulse
measuring device to display the pulses and the engine is cranked by using the ignition switch.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer,. actuator & sensor wiring
Fuse panel layout
Vacuum routing
Thanks a bunch guys! This is what makes these kind of forums great. Jrichker, that is some amazing info. Very nice diagrams.
THE CAR IS NOW RUNNING!
The problem was actually the TPS. At closed throttle it was showing 4.3v. Do you want to know the crummy part? The only sensor that I replaced during the entire time that wasn't on the car before . . . the TPS. I never knew if could casue a "no start" like that. Learn something new every day. Again, thank you so much. I will post up a video when I get out and drive it!
Thats odd, usually the TPS voltage not coming back to less than 1 volt sets code 53, throttle
Position sensor too high – TPS – TPS out of adjustment, bad connections, missing signal ground, bad sensor.
I'll have to add that to the "Cranks OK no start checklist for fuel injected Mustangs".
Glad I could help you out as well. Even though I almost blew up my car a few times in the process. LOL I wanted to push the stupid thing off a cliff! But . . . all is good now. I am again at peace with EFI.
