Ok. There is a lot more to the story, that I will (try to) say in a nutshell.
Car was leaking oil badly about 4 weeks ago. Brought it to Ford, they fixed it (under warranty). It was a really simple fix. The fixed it, added oil, and a new filter.
Since then, I've driven it pretty hard-- as I usually do.
Then, on the freeway last night, I was driving it really hard. Realllyyyy hard. Winding it up to 6K a number of times, flying through the gears. It was kinda difficult to hear anything over the h-pipe, but when I let it get down to 2K or so, I heard a loud clunking that was only present during certain RPMs. At idle, you can hear the clunking. Then, at around 2K, you can hear it, then, just shy of 3K its present, as well.
This is the weird part. I'm usually very good about checking my oil regularly, but the past weeks have been pretty crazy, and blah blah... I never did as I normally do. On the way to the dealership, my oil gauge is bouncing from zero, back up to half. I immediately pulled over and check oil. Nothing! wow. Put 4 quarts in, and went up to full on dipstick. They're fault for not properly fixing leak.
Noise was not as loud, but it was still there.
One last thing...
I took it to Ford, and serv. mgr. said, no prob. Its all under warranty and we will fix whatever it is. BUT my concern is what was damaged w/o oil during those high revs. Also, what is the integrity of the service mechanics? I know they have to replace what is actually broken, but what about if I fried some rings, or something like that? Should I go down there w/ someone when the engine is apart, and look myself? Do you think they will really replace what endured excessive wear during the no-oil-high-rpm runs?
Thanks for the input
One last thing...
who can resist floorin these cars? not me! Even though mine breaks belt tensioners like clockwork, I hadn't floored the thing in a week. I couldn't take it anymore. I floored it. It has broken the belt tensioner in two on a few power shifts into second and third. its retarded
