The other day i started my 95 and it ran for about 45 second before it died. I am not getting any spark from the coil, but the coil does have power going to it. I tested the coil, and it checked out ok. I had the TFI checked and that seems to be ok. I used a test light and i have power to the injectors. I checked the fuel pump, and it's working. I just purchased a noid light and i will check it tonight to see if the injectors are pulsing. If the injectors are not pulsing, could it be the PIP. If the PIP is bad would this cause the coil to not throw a spark?
By the way, before i started the car for the last time, i tack welded something on the exhaust and the battery was still hooked up.
Could this have caused the problem????
Thanks,
Thanks,
