- May 4, 2007
- 313
- 3
- 19
Moved the 67 out of the garage last night to do work on the DD (yes, that's how I spent NYE), and when I went to start it this morning the starter turned the engine but the car wouldn't start. After various shenanigans, I've determined that there is gas jetting into the venturis (sp?), the distributor appears to be turning the rotor, but there does not appear to be spark from the coil. I used the hold the wire with insulated channel locks and look for the arc method to determine this last matter.
I'd appreciate suggestions on what else to check before replacing the coil. Also, how much better are the "Flamethrower" coils. I'm kind of stuck with what's on the shelf at the local parts stores, but I'm thinking about a PerTronix upgrade for the ignition and they recommend pairing it with their coil (as they would).
