  • 1994 - 1995 Specific Tech
no spout connector !!!
  • Thread starter Thread starter rhsty
  • Start date Start date May 15, 2006
R
rhsty
9
vestal ny.
May 15, 2006
  • May 15, 2006
I bought the car a little over a year ago,The car originally had for a better word a 302 cobra setup
in the car.Now I am just about ready to fire up my
new 347 crate and noticed that there is no spout
plug in place so initial timing can be set but was
worried on how the car will/did run without the
spout plugged in.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
May 15, 2006
  • May 15, 2006
if your gonna be driving it with no spout i would run around 25 degrees timing
you could use a paperclip to jump the two wires together and itll act like the spout is back in and you can run it at the normal 10-14
Black95GTS
1,644
Marlborough, MA
May 15, 2006
  • May 15, 2006
The car will run fine up to a point. All you will be doing is locking out the timing adjustment. IMO, unless this is a track only car, this is a waste.
If I were you, I'd head to a junkyard and pull out a spout from another engine. I believe the search function could find you other models besides stangs that also used the same connector. Should be pretty easy to replace it.
yellowstang1994
338
  • May 15, 2006
When I bought my car there was no spout in it. After my PIP sensor went out it took me a while to realize what was going on. I found a new spout and put it back in and ran 10 degrees timing. Ever since then I had detonation problems with it. I'm going to take the spout back out to keep the computer from messing with the timing and run 25 degrees and see how that does.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
May 15, 2006
  • May 15, 2006
Some folks rig up a switch to the SPOUT so that they can switch it on and off (like taking it out and putting it back in). If you don't want/need to do that ... just go to a junkyard and scout one out.
mytight95
2,605
Dothan,Al
May 15, 2006
  • May 15, 2006
ford sells them for less than 10$ i had to replace mine.
jason
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Engine Spout connector (Code 18)
  • 5.0-5MT
  • Jan 24, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Jun 15, 2024
5.0-5MT
