no start got fuel pressure spark and pulsating inj.
zss42002
38
a little background. just installed a rebuilt 306 and put a kenne bell 2200 on it. its a 5.0l and got all new msd stuff dist. ign. box and coil. new plugs and all. i have 90 mm maf. ba2400, and 50ib delphi inj.
my problem is i cant get it to start. the car cranks over but doesnt seem to be geting fuel. i tested to see if i had spark and i do. i got a node light and the inj. are pulsating. got the num. 1 piston on tdc and put the dist. in pointing to num. 1. all wiring was checked many times and is correct. i have a mallory 4306m ruel rail with a fpr mounted to the front. i also have a gauge on it and it shows way more than the 60psi gauge can read. have a 255 walbro too. i cracked the line on the fuel and on supply lines i got fuel but on return there is nothing could that be a issue. could the inj. all be bad.??
ive read thread and threads and have tried everything i am out of ideas anyone please have any idea? or tips?
forgot to mention i pulled #1 and 5 spark plug wires and they are not wet, drenched, or smell like fuel.
Ok when the fuel pump primes the preure on the gauge burries then it goes to around 30 40psi. But like I said b 4 spark plugs r not drenched in fuel or smell like it what can b the problem
Having the piston at TDC and the rotor pointing at #1 cylinder does not guarantee that the distributor is installed correctly.
Putting the distributor back in and setting the timing.
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole,
crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer on the engine block.
The distributor starts out with the #1 plug wire lined up at about 12:00 with you facing it. Align the rotor to about 11:00, since it will turn clockwise as it slides into place.
Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block, (you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing.
If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor, but don't tighten it too much, as you will have to move the distributor to set the timing. Note that there is no such thing as one tooth off on a 5.0 Mustang. If it doesn't align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range.
Setting the timing:
Paint the mark on the harmonic balancer with paint -choose 10 degrees BTC or 14 degrees BTC or something else if you have NO2 or other power adder. I try to paint TDC red, 10 degrees BTC white and 14 degrees BTC blue.
10 degrees BTC is towards the drivers side marks.
Simplified diagram of what it looks like. Not all the marks are shown for ease of viewing.
ATC ' ' ' ' ' ' ' ' ' '!' ' ' ' ' ' ' ' ' ' BTC
---------------- > Direction of Rotation as viewed standing in front of the engine.
The ' is 2 degrees.
The ! is TDC
The ' is 10 degrees BTC
Set the timing 5 marks BTC. Or if you prefer, 5 marks towards the driver's side to get 10 degrees.
To get 14 degrees, set it 7 marks BTC. Or if you prefer, 7 marks towards the driver's side to get 14 degrees.
The paint marks you make are your friends if you do it correctly. They are much easier to see that the marks machined into the harmonic balancer hub.
At this point hook up all the wires, get out the timing light. Connect timing light up to battery & #1 spark plug. Then start the engine.
Remove the SPOUT connector (do a search if you want a picture of the SPOUT connector) It is the 2 pin rectangular plug on the distributor wiring harness. Only the EFI Mustang engines have a SPOUT. If yours is not EFI, check for a SPOUT: if you don’t find one, skip any instructions regarding the SPOUT
Warning: there are only two places the SPOUT should be when you time the engine. The first place is in your pocket while you are setting the timing and the second is back in the harness when you finish. The little bugger is too easy to lose and too hard to find a replacement.
Start engine, loosen distributor hold down with a 1/2" universal socket. Shine the timing light on the marks and turn the distributor until the mark lines up with the edge of the timing pointer. Tighten down the distributor hold down bolt, Replace the SPOUT connector and you are done.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
attachment.php
i put the dizzy in as described above and took out the num. 1 spark plug as mentioned in the post. the only thing that is different that i did was number one is not really at 12:00 for me its like about 1. but i lined it up with the num1 on the dizzy cap. could this be throwing something off? should i put in rotor at tdc and align it at 12:00 and put the cap num 1 on top of the rotor that way? also as stated before it shouldnt matter if i am at 1:00 b/c being one tooth off isnt much of a big deal if i align it up right.
as some one was cranking the car i was playing with dizzy left and right to see if anything would change and nothing did if this helps at all.
i cant use a timing light if the motor doesnt start correct?
i think we are all missing the real problem i am not getting fuel to the piston. could this be because of not aligning the dizzy at 12:00? or i am not smelling it or seeing it b/c it is such a small amount?
I know you used a noid light but if you have the Key on/engine off and you turn the dizzy, do you hear the injectors click?
If you do (and/or you use the noid on the other injectors and the light illuminates), I'd ensure the injectors are spraying. It would seem that even if the timing was off, your plugs should be wet.
Do the checklist...
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 16-Jan-2011 to clarify testing the EEC relay in paragraph 1E .
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
i have done the checklist many times and still nothing i am gonna get a new dizzy and try that im out of ideas
What happens when you spray starting fluid in the intake and try to start the engine?
What happens when you try starting the engine with the SPOUT removed?
I do have 12 volts on red wire and as posted b4 they are pulsating b/c node light lights when cranking I will test ohms of injextors when I get home. They are delphi 50 ibs and have same connectors as stockers
Also if you google them they say they are 12 ohm high impedence if that makes any sence.
could it be that i need to get it tuned? i got the stock ecm and bigger inj. and bigger maf. and the ecm is prog for stock stuff?? does that make any sence? someone told me this but i told them it should do something backfire or almost start or start and run like crap am i correct?
I think even if you get it to run, it's going to be a mess.
50lb injectors are too much, should of used regular 42's, the mass air meter you have (better known as an SCT2400) requires a custom program for the computer, it's meant to be used on modular engines that no matter what get a custom tune.
Pretty much all the msd stuff is problematic, especially the distributor.
Get a DBX or pmas meter with 42's.
The parts you are currently using complicate a very simple situation.
Put simple proven parts in.
Even try the stock meter with 19's.
so until its is tuned it wont start is that what you are telling me?
Honestly, I don't know.
I do know this, i got the 2400 on my 03 cobra setup from a guy at my buddies shop for $50 that had it on a notch that had to be towed in because it wouldn't run. I got the meter and an adapter (that i threw out) to connect it to the fox harness.
Now, why it wouldn't run, i have no clue, they told him to ditch the meter and i bought it. By the time i came back again the car was gone.
Should only take a couple minutes to put a stock meter and 19's on the car.
Try them and see.
Regardless, the meter and injectors you have are the wrong parts for the job. With a custom program it may run ok, but it's still going to cost you more in the long run and create headaches. They are definitely more trouble than they are worth.
If i were you i'd start by removing the variables, bypass any aftermarket ignition (at lest temporarily) and swap in the stock meter and injectors.
well got it started with starting fluid my problem is deff fuel. pinpointed down to either fuel inj. or fuel pressure reg. gonna call mallory and see what they say about the fpr if its hooked up right or if i can check to make sure pressure is going to rails or what b/c its funny to me that if the node light blinks i should be getting fuel to the head. what is funny to me is my pressure gauge 60psi maxxes out when i start the car when the pump primes and then it comes back to like 30 or 40 after shutting key off. and stays pressureized. if i crack the return line there is no fuel in that line is that normal?
