No Throttle Response
  • Thread starter Thread starter 89superstang331
  • Start date Start date Jul 22, 2009
89superstang331
  • Jul 22, 2009
I have an 89 GT that I just rebuilt the motor in after bending some valves. I bumped the compression from 9.3 to 10.75 other thenm that the motor is the same as iy used to be when it ran fine. I have also lengthened some of the wires on the harness that goes to the mass air and O2 sensors. Now I have tried to start it and it will only run if the throttle is wide open but will only run around 1500 rpms and when you let off the throttle it dies. The exhaust smells very rich and the plugs look a little wet when i pulled one out. I have tried unpluging the mass air, the idle air sensor, took off my Anderson PMS system, Checked for vaccum leaks, and checked the timing over and over. Can anyone help or have an idea. THANX
BYRDPE
1,556
Memphis,Tn.
Jul 22, 2009
  • Jul 22, 2009
BYRDPE
1,556
Memphis,Tn.
Jul 22, 2009
  • Jul 22, 2009
BYRDPE said:
i say the timing is still off. more than likely retarded.
pull the #1 spark plug, remove the coil wire and have someone bump the starter while you hold your finger over the spark plug hole until you feel the compression. then unsnap the dizzy cap to see where the rotor is pointing in reference to the #1 terminal on the cap.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 23, 2009
  • Jul 23, 2009
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Electrical Stumped No Start...
  • sydhawk
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
sydhawk
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
