No Throttle Response
89superstang331
I have an 89 GT that I just rebuilt the motor in after bending some valves. I bumped the compression from 9.3 to 10.75 other thenm that the motor is the same as iy used to be when it ran fine. I have also lengthened some of the wires on the harness that goes to the mass air and O2 sensors. Now I have tried to start it and it will only run if the throttle is wide open but will only run around 1500 rpms and when you let off the throttle it dies. The exhaust smells very rich and the plugs look a little wet when i pulled one out. I have tried unpluging the mass air, the idle air sensor, took off my Anderson PMS system, Checked for vaccum leaks, and checked the timing over and over. Can anyone help or have an idea.:shrug: THANX
i say the timing is still off. more than likely retarded.
pull the #1 spark plug, remove the coil wire and have someone bump the starter while you hold your finger over the spark plug hole until you feel the compression. then unsnap the dizzy cap to see where the rotor is pointing in reference to the #1 terminal on the cap.
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Alternate methods:
Or for a nicer scanner see Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
