Tonight I found out how crappy and worn the stock suspension is on my 89gt.
I was coming home from work a little while ago. I pulled up to a stop sign and proceeded to make a 90 degree left turn. I pushed the throttle a little bit more than I should have. Which put me into a sideways skid. I overcorrected and put it sideways again. Then ended up nose first facing the sidewalk.
I never had the engine over 3000 rpms. It went wonky faster than I expected. I have had problems with traction through the corners when the roads are wet.
So where should I start to fix this? I would assume shocks, springs, and new bushings.
What else can I do?
What else can I do?
