no turn signals
Flasher modules have 2 differennt failure modes. The more common causes the lights to stay on steady. But flasher modules can also fail such is to give the symptoms described. The same symptoms would result if the connector or a wire fell off the module.
The flasher module should have 5 wires:
Purple/orange stripe
Red/white stripe
Black
Light blue
White/red stripe
Do both your brake lights and back-up (reverse) lights work? The flasher circuit fuses (#1 and #9) are common to the brake and reverse lights. Fuses can look fine but still be open.
