I changed my trans fluid the other day and last time I put Dexron III in it and it was fine. This time I put Valvoline Dexron III/Mercon combination fluid in there since that was all they had. Plus it was the high mileage stuff too.
Now on the freeway in 5th gear it will make a metallic gear type noise. I thought it was a wind noise at first but its coming from the transmission area. If I put my foot on the clutch it will still do it. If I take it out of 5th into 4th or neutral it will go away. Plus when it warms up it seems to go away. Do you think there is something wrong with the fluid I used? I'm doing my brakes in a couple of weeks and can change it again or should I change it sooner?
One other non related thing. Lately I have been hearing my front shocks when I go over bumps making the typical air pssst sound like you would expect from shocks. I don't remember hearing that before. Is that a potential problem?
it sounds like metal on metal or like somthing is loose since is comes and goes, but when it's really cold it's sounds really bad.
