Hi I have a 1995 mustang. From underneath the hood you hear a sort of squealing noise. Its not to loud but enough I would like to fix it. I have read many forums, and discussions on serpentine belts, belt tensioners, and idler pulley's. Now first off I know that my Idler pulley needs to be replaced, its bearings are going out. And therefore I will be replacing it this weekend. Now for the squeaking I haven't a clue what could be causing it. I read that a slight mis-alignment of the belt could be the problem, but I don't see any of that at all. People say that the belt tensioner is supposed to move because its spring loaded, mine does not seem to want to move and out of not wanting to break it, I did not force it up. Aren't you supposed to be able to move the belt tensioners arm up so that you can replace the serpentine belt? Or is there something I missed. I have a Goodyear belt, so it has been replaced before. I have also read many complaints about these belts that they always cause squeaking. In any case even if it was the belt, pulling up on the tensioner didn't seem to make it move.
Any help would be GREATLY APPRECIATED!
P.S - Please don't refer me to any other posts, I have read all of them concerning my problem.
