Folks, I'm looking for some help in diagnosing my very noisy Aluminator engine.
Here is a link to the video:
YouTube - NoisyAluminator.wmv
Details are as follows:
M-6007-A46SC (FRPP Aluminator long block for supercharging)
Built 8/2/2010
S/N R07400588
Installed 12/2010
200 miles on engine, 15K on car
Engine is completely stock, except for full exhaust and a K&N filter.
Issue #1
The engine sounds like a diesel while warming up. (It did this a little at new, but is getting worse.) It is quiet for the first minute or two after startup, then rapidly starts “clacking.” It is very loud, and I can hear it echo off buildings with the windows down, and I can hear it with the windows up inside the car. It is mostly at idle, though I can also hear it driving at 2500 RPM. Once the engine is completely up to operating temperature, I can hardly hear it.
• Main oil pressure is 90 PSI at startup, and 30 PSI at operating temp. I cannot remove the pugs on the heads to check head pressure, but based on using my ears and stethoscope, the valvetrain is not the source.
• Engine has been filled with 5w30 conventional oil since new
• With a stethoscope, the noise is loudest touching the block, near the freeze plug at the rear driver’s side of the engine.
• Depressing the Clutch pedal has no effect.
Issue #2
There is a valve ticking on cylinder #3 or #4. I can’t get my stethoscope on those header primaries to verify which one. It is most audible at idle. Off idle, the rest of the engine noise covers it up.
The noises of this engine are disturbing, and much louder than I feel is “normal” (especially for a $6500 engine with only 200 miles!)
I appreciate your help.
--Wes
Built 8/2/2010
S/N R07400588
Installed 12/2010
Issue #1
Issue #2
--Wes
