  • SN95 4.6L Mustang Tech
noisy engine
  • Thread starter Thread starter toygt4.6
  • Start date Start date Feb 1, 2006
T
toygt4.6
middleburg fl
Feb 1, 2006
  • Feb 1, 2006
myu car makes a noise from 1100 to 1400 and it sounds like a rattle but its from the engine it doesnt sound serious but i cant figure out what it is any sugestions will help i cheked my pullys by taking of the belt the noise was still there the car has les than 60,000 on it
97gtconv.
244
Lock Haven, PA
Feb 1, 2006
  • Feb 1, 2006
just going to throw this out there, check your pullies and idler gear...
USMstang
114
Mississippi Gulf Coast
Feb 1, 2006
  • Feb 1, 2006
I also have a minor noise from under there somewhere. My Ford service manager buddy said it may be the cam syncronizer. Because the noise has not progressed into anything scary, I'll change the idler pulley first. I'm thinking it will be much cheaper and easier!
97gtconv.
244
Lock Haven, PA
Feb 2, 2006
  • Feb 2, 2006
here's some cheap techniques that might help you, only and only if you have a really really long screwdriver put it on various non-moving parts. Put it up to your ear and listen for noise. A stethascope is prefered but the screwdriver does work. Last week i thought my motor was dead, it was making a dreadful knocking chattering noises, i found out using a 2 foot screwdriver that my idler gear went bad. i put a new one and that cured it. make sure your diagnosis of the problem is correct... don't spend money on stuff you don't need. double and triple check and have other people give their two cents. good luck, troony
the98stang
2,408
Clovis, CA
Feb 2, 2006
  • Feb 2, 2006
Does it sounds like a rock rattling in a coke can? If so, you may have rod knock, which is not good. Try to pin point where the noise is coming from. If the knocking gets louder/fast when you accerlate, its probably rod knock. Get a compression test done and make sure the cylinders have good pressure. You could also hook up an oil pressure gauge and make sure the engine has adequate oil pressure. Metal shavings in the oil might also indicate rod knock or a spun bearing.
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
  • Gulftown980x
  • Jul 29, 2026
squeak93
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
