here's some cheap techniques that might help you, only and only if you have a really really long screwdriver put it on various non-moving parts. Put it up to your ear and listen for noise. A stethascope is prefered but the screwdriver does work. Last week i thought my motor was dead, it was making a dreadful knocking chattering noises, i found out using a 2 foot screwdriver that my idler gear went bad. i put a new one and that cured it. make sure your diagnosis of the problem is correct... don't spend money on stuff you don't need. double and triple check and have other people give their two cents. good luck, troony
