Non Mass Air Mods?
  • Thread starter Thread starter jpchefz
  • Start date Start date Dec 1, 2010
jpchefz
10
Fort Wayne, IN
Dec 1, 2010
  • Dec 1, 2010
I have an '88 GT without Mass Air. Was thinking of adding a Cobra intake and 65MM Throttle Body, 24# injectors and new heads. My question is this. I have heard that you can only go so far modding a Non Mass Air car, before you start having driveability issues. Is this true? Any tricks to modding a car without mass air?
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Dec 1, 2010
  • Dec 1, 2010
Most of the time if you don't touch the cam you will be ok
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Dec 1, 2010
  • Dec 1, 2010
Can't (or at least, shouldn't) change injectors without a tune.
Speed density relies heavily on manifold vacuum during idle and part-throttle conditions. Camshafts that reduce manifold vacuum (pretty much any aftermarket cam to some extent) will "confuse" a speed density computer, causing drivability issues. Milder cams have less of an effect on this than "bigger" cams do (longer duration, longer overlap).
You can get away with speed density to an extent, more if you're willing to raise the fuel pressure once the 19lb/hr injectors reach their limits on stock fuel pressure.
My car is still speed density, and I have a (very lightly ported) GT40 intake, 70mm TB, CAI, full exhaust, etc. Runs fine.
Kdubslugga
1,515
Akron, OH
Dec 1, 2010
  • Dec 1, 2010
Yeah no need to change injectors yet. Cobra intake is a good choice. I made 495 rwhp with one, so you have some room to grow with it. As long as you dont do heads or cam you should be fine. Some things to consider, like you said Throttle body, Electric fan, bump the timing, pullies, headers, hpipe, flowmasters, cold air intake. Along with the intake those upgrades would be ehhh maybe 40 more HP give or take depending on what you have already done!
jpchefz
10
Fort Wayne, IN
Dec 2, 2010
  • Dec 2, 2010
Thanks for the info. I appreciate the input.
brands5.0
577
miami ,florida
Dec 2, 2010
  • Dec 2, 2010
Its all in the tune most of the big EFI systems are non mass air F.S.A.T BIG STUFF 3. A good tuner should be able to tune the car for any planed mods.
P
phutch11
328
Dec 2, 2010
  • Dec 2, 2010
There's a member of this board, TMoss, that made something like 277rwhp with a non-tuned SD system.
IIRC his combo was some ported GT40p heads, stock cam adv 4 degrees, 65mm throttle body, and a ported corba intake. I'd guess he probably had some decent headers, exhaust, e-fan, pulleys, and other supporting mods as well.
277rwhp is no joke on stock Ford parts. Lots of guys struggle to get that high on a MAF system with similar (or better) parts.
Just a thought...
Good luck...
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Dec 4, 2010
  • Dec 4, 2010
I have the same mods on my 88. Runs fine. Keep the stock 19# injectors and don't touch the cam. Car will run fine.
Some guys claim sd can't handle bolt ons like that, but i can show you my 88 idling smoothly with intake and exhaust mods....pretty much everything but cam and injectors
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Dec 5, 2010
  • Dec 5, 2010
This thread got me thinking.
If you put an adjustable fuel pressure regulator on the car and knock the fuel pressure up to 60psi, the stock injectors could support 350 hp at the flywheel (theoretically). That's based on this injector calculator and using .45 BSFC and 85% injector duty cycle. Also assuming your fuel pump is up to snuff. Also don't know how part throttle A/F would look, this is only concerning WOT.
So I'm thinking... Big intake, big heads, mild cam, supporting mods, and stock SD system with 19 lb injectors. 310ish rwhp?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Dec 5, 2010
#10
  • Dec 5, 2010
  • #10
At that point why not convert to MA? It's only maybe $200 in parts.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Dec 5, 2010
#11
  • Dec 5, 2010
  • #11
More or less, just so you could say "I made 300 to the tire on 19lb injectors and speed density" haha.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
